Leaf spring shackle bolts
Discussion in 'Technical' started by t.ramsey, Jan 15, 2010.
  1. t.ramsey
    t.ramsey Member
    austin,tx
    both
    Has anyone replaced just the bolts in there leaf spring shackles? I found 1/2" grade 8 bolts that seem to fit perfectly. I plan to grind a small collar on them so I don't over tighten the bushings. Does anyone see a problem with this?
  2. paxtond
    paxtond Member
    Ontario
    1971, 1976 Comets
    You can buy new ones at Rock Auto for $15.00 a side. A lot safer choice for $30.00
  3. Craig Selvey
    If you are talking abput aftermarket shackes (the long ones)....I would suggest getting rid of those.
    Factory shackles didn't have any bolts. They were an assembly.
  4. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    The factory ones are way stronger.
  5. t.ramsey
    t.ramsey Member
    austin,tx
    both
    I meant removing the pressed in factory bolt and replacing it with a grade 8 bolt. Rock Auto shackles ar $20 each plus shipping.
  6. PAINTANK
    1973 Comet 2 dr
    My factory ones didn't allow for my immense tires so I was forced to use shackles. In a perfect world i would have high arched springs and factory style shackles.
  7. crazy carl
    crazy carl Member
    frankfort ky
    1972 maverick
    if anything would brake is the leafspring
  8. paxtond
    paxtond Member
    Ontario
    1971, 1976 Comets
    listed right now at $17.66 (1971-1973 Comet) if we're splitting hairs, must have went up since last week when I bought mine...they were $15.62, just got them Monday.
  9. 71gold
    I used...self locking nuts...on mine...:yup:
