Leafsprings
Discussion in 'Parts Interchange' started by Racer_X, Dec 11, 2008.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    will mustang leafsprings bolt on to our cars?:huh:
  2. Mavman72
    Nope...Spring eyes are further apart(main spring is longer)
  3. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Nope, but Econoline 150 van springs will. Got mine for $40 at the junkyard.
  4. Darwin'sheros
    Darwin'sheros Member
    Layton, UT
    1974 302 Maverick
    I found some leaf springs for not too much, and they're made specifically for Mavericks (says custom fit for 74', but they're all the same.)
  5. facelessnumber
    Memphis, TN
    '71 Grabber
    Yeah, from what I've read you can't go wrong with the JC Whitney springs if you're looking for stock replacement with a little more load capacity. Lots of people on here use them.
  6. bmcdaniel
    Once upon a time in the 70s I added leafs from a station wagon to mine. Kept the large top leafs bolted in, removed the lower leafs, and added the lower leafs from the wagon. A few C-clamps and a longer center bolt was all it took. Jacked up the rear pretty high without needing air shocks. Rode like a station wagon, too. :rolleyes:
