Leaking around shift levers
Discussion in 'Transmissions' started by satchelmcqueen, Jul 11, 2019.
  1. satchelmcqueen
    satchelmcqueen Member
    north georgia
    What gasket or o ring do i need to stop a big leak around my shifting levers on the stock 250 c4? And is it easy to change? Never done this.
    Its didnt leak at all until i installed the b@m megashifter lever. It started a few drops and a month later its a puddle. I did have to remove the kickdown nut to i stall their bracket so i wonder if i jostled something?
  2. 71gold
    it's a seal and an O ring. there's an O ring behind the nut and lever on the outside of the transmission. replace it first that might be your leak,
    satchelmcqueen likes this.
