Leaking Heater line fitting
Discussion in 'General Maverick/Comet' started by Maverick Dude, Aug 5, 2015.
  1. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    What's the best way to deal with this heater line fitting on a 73, 302. Would I be able to get a totally new fitting and if so what are the odds it will snap off when I wrench it off. Thanks for your input.
    M.D.
  2. 71gold
    best chance is to soak it with PB blaster a couple days before trying to remove it. doesn't look all that bad to start with...have you found a replacement ?
  3. Maverick Dude
    Couldn't see it in the Melvin's catalogue. I'll try our local auto parts store later this week. Do you think this available at conventional aut0 part stores?
    M.D.
  4. 71gold
    be easier to find a fitting if you don't have smog regs.
  5. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    I think they are 1/2 pipe thread a nipple tee a vac fitting and a push lock fitting for the hose will work it won't be pretty but it will work till you find a replacement spray blaster on it let it soak then turn it as gently as possible
  6. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    A little trick to removing any pipe thread fitting is to tighten the fitting as little as 1/8 or less of a turn before you try to remove it .
    Maverick Dude and 71gold like this.
