LED instrument lights
Discussion in 'Technical' started by EFIMAV, Aug 19, 2013.
  1. EFIMAV
    EFIMAV Member
    Davenport Iowa
    I've read the archives and it appears there are a hundred ways to improve the dash lighting. I was thinking about replacing the three 194 bulbs that illuminate the gages with these. I figured the warning lights are fine with 194s. The description indicates that they are plug and play. I assume they have resistors in them. Thoughts?
    http://www.ebay.com/itm/10pcs-LED-T...Parts_Accessories&hash=item46112f5a65&vxp=mtr
  2. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    i put those in...my lights still suck so bad i cant even read my fuel guage at night..have to put my phone near it to see..i've painted the insides and changed lights 3 times (different types) and tried a different cluster..all this really made no difference for me.
  3. rthomas771
    I did about the same as ESampson and had the same results. I ended up using LED's and putting on the Whiteface under lay and now I can see the fuel gauge at night.
    Ford Freak and Ford_Life like this.
  4. mavgrab302
    I did this, I can see them great now...
  5. simple man
    simple man Member
    Bunnell,Florida
    I used the stock 194 bulbs ( new ones ), painted the cluster interior with Krylon Fusion for plastic ( gloss white ), and this was the result! I actually like the amber better than the blue. Notice the shift indicator. I haven't given it or the heat - ac panel the " treatment " yet. :)
  6. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    Mine isn't even close to that..I'd e totally happy and satisfied with that. Guess he can give it a shot and see if it works for him..
  7. EFIMAV
    EFIMAV Member
    Davenport Iowa
    thanks for the responses
  8. z28th1s
    Lynchburg, VA
    I was wanting to upgrade my dash lights for the same reasons as people stated above. I can't see my fuel gauge at night either. I have used LED's in other applications on later model cars and they worked well.
    That being said, I haven't had my cluster out the car yet. I'm not sure exactly what you are painting gloss white to get the look you have, which looks very good and easy to read. Could you help me out?
    Thanks!!
  9. mojo
    The green plastic housing containing the gage assembly. Also, u can get different color gage face decals that adhere directly to the orig faces to brighten things a bit/lot more. www.whitefacegauges.com
    I did mine in white face. Check last 2 pix on page 4 in my gallery to see what needs painting and finished gage cluster.
  10. Dave B
  11. z28th1s
    Lynchburg, VA
    Thanks guys I will try working on this over the weekend!
  12. John Holden
    John Holden Member
    NJ
    I don't know about the ones on eBay. I bought some at Advance Auto by Sylvania I think. They were pretty expensive but they made a very noticeable difference.
  13. mojo
  14. z28th1s
    Lynchburg, VA
    I still like the idea of LED's. I think I bought some from a place called Super Bright LED's for my 2011 Mustang GT and they worked VERY well in the map lights.
    Thanks for the info!
  15. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Do the LED 194s work with the dimmer (not that I would ever need to dim them, 'just curious)?
