Left turn signal works, but not right???
Discussion in 'Technical' started by Chenny94, Jan 29, 2014.
  1. Chenny94
    Chenny94 Member
    1974 Maverick
    I know no bulbs are blown, gotta new flasher, but my mechanic put a turning switch in and the left works, but not the right. We are both stumped. Any help?
  2. scooper77515
    Does the dash indicator blink at all, or come on solid?
    Does the rear or front come on at all?
  3. Craig Selvey
    Did your mechanic replace the entire turn signal switch?
  4. Chenny94
    Chenny94 Member
    1974 Maverick
    No indicators on the inside. All the lights work. Just no right turn signl.
  5. Krazy Comet
    If the brake lights work OK but right is out with signal on, problem is likely a bad signal switch(yes I read the part about being new)... If it's NOS then possibly has corroded contacts and some electrical spray cleaner in the turn & four way flasher switch may get it operating...
    Power should be verified on the white/blue(RF) & orange/blue(RR) wires at the crescent shaped connector on switch, BUT again if brake light operates the circuit is good from connector to tail lamp...
  6. Bryant
    how do you know all the bulbs are good?
    if the front bulb has the turn signal element is burn out, it will still light up with running lights but wont light up for the turn signals. if a bulb is out the resistance wont be high enough in the circuit to trip the flasher
