Life Span Of Glasspacks?
Discussion in 'Technical' started by Slider28, Mar 25, 2010.
  1. Slider28
    Slider28 Member
    San Antonio, Texas
    72 Maverick Grabber 302
    Can somsone tell me the typical lifespan of glasspacks?? mine have been on the car for probably 20-30 years, i hear the fiberglass breaksdown and gets plugged.. So i was curious about the life span.
    Thanks!
    Chaz.
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    If they have been on there that long, I'd say you got your money's worth.....
    Unless it's stainless or even the aluminized steel, most exhaust parts with the exception of cast iron manifolds don't last but maybe 10 years max, less if in a salt enviroment.
  3. maverick75
    It's time to upgrade:thumbs2:to the dynomax bullet...
  4. scooper77515
    All the glasspaks I ever used lasted until they rusted through. As the fiberglass breaks down, they start to sound better...:D
  5. Thrashin302
    Thrashin302 Member
    South Dakota
    I agree with Scooper.haha. but i suppose tho if mine were that old id probably cange em out to.
  6. Earl Branham
    Lugoff, SC
    Lifespan on a glasspack is 1 (one) backfire!
  7. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    ...Like wine and cougars, glasspacks improve with age.
  8. Slider28
    Slider28 Member
    San Antonio, Texas
    Well, im noticing when i let off my exelerator, say after going 70 on the hwy, the engine feels like it cant breathe, maybe back pressure? Ive had several people tune it up and adjust the timing.. Had electronic igniton put on, but it seems like something is plugging up the engine (exhaust) even trying to do a steady 70mph, still has a SLIGHT holdback... thats why im going to change the glasspacks...
    What do the Dyno Max bullet sound like??? I want a 70's sound, not a 90's hollow mustang exhaust sound.
    Chaz.
  9. maverick75
    The bullet is basically a modern glasspack.....
    The hollow sound usually comes from a chambered muffler like flowmasters or Turbo mufflers..... which were available from the factory on some 70's muscle cars.
  10. maverick75
    glasspack's have very little back pressure and if they wore out im guessing they would have even less
  11. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Has the car always felt like that? Older cars don't free wheel like the newer overdrive and more fuel efficient cars do.
  12. Slider28
    Slider28 Member
    San Antonio, Texas
    I Had a 70 mach1 and a 65 mustang convertible, that didnt do that when i let off the excellerator... But this car seems to have always done that, but ive only had it on the road for about 1 year...
    Chaz.
  13. Earl Branham
    Lugoff, SC
    That is the gearing that you are feeling. Newer cars have overdrive, and lower compression, so they slow the car less when you back off, although they usually have steeper gears in the back end.
  14. Slider28
    Slider28 Member
    San Antonio, Texas
    So in otherwords, the guy who told me the glasspacks breakdown and clog your exhaust didnt know what he was talking about???
    Chaz.
  15. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    I've never seen glasspacks plug up. Like others have said, older they get the louder or better they get! Depends on how you look at that,,,, The fiberglass burns/blows out the pipe, taking the sound deadener out of them. If they sound and look good,,, why spend your $$$?
