Location Template for Small Rear Bumper
Discussion in 'Technical' started by rotorr22, Sep 15, 2014.
  1. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Does anyone have a good location template for drilling the small rear bumper mount holes? I'm currently converting a large bumper '74 to small bumpers.
  2. doncomfort
    chillicothe oh
    I can probably make you one off the 71 shell.
  3. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Thanks, Don.
    I want to get all of the holes drilled before it goes to the body shop.
  4. doncomfort
    chillicothe oh
    I will make one for you after work today. I will be in Plymouth on Saturday. Is that far from you?
  5. mavgrab302
    Don't forget you need the 70/72 braces that weld to the floor and tail panel. Just bolting it through the tail panel wont be strong enough. I think the early mustang braces can be made to fit...
  6. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    It is about 2.5 hours away.
  7. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Yes, I am aware of that. Not sure which year Mustang braces fit the best. One member said 67.
  8. rthomas771
    I use a ruler to find the center line and went from there. I used the '69-70 Mustang mounts on the trunk floor...they are a little longer than the 67-68 mount.
  9. doncomfort
    chillicothe oh
    I made you a template Ed. It's ready to mail tomorrow. The template uses the heavy body line and the hole for the license plate light wire for alighnment.
  10. braess
    braess Member
    Buchs Switzerland
    Ford Maverick GT 1974
    Could you pass us on the measurements and some fotos that we can fabricate our own template? I would need that as well for my conversion! Thanks
  11. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Thanks, Don. You da Man!
  12. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Thanks. I ordered a set of 69-70 Mustang braces.
  13. doncomfort
    chillicothe oh
    No Ed, YOU da man!!
  14. doncomfort
    chillicothe oh
    You should have your template tomorrow.
  15. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Thanks, Don. Jordan and I will be working on it this weekend. Soda blaster is scheduled for Monday!
