Log head replacement?
Discussion in 'Maverick/Comet Projects' started by jwarmentrout77, Jan 12, 2016.
  1. jwarmentrout77
    jwarmentrout77 New Member
    dallas, tx
    70 maverick
    70 mav, i-6, 200 ci. has log head, intake unit. want a head with separate intake, for either tw0 2 barrels or three 1 barrels. have looked at the offenhauser 5970 unit which works but want something with more flow. porting the intake on a log head just doesn't seem worth the effort. anybody got a source for a cylinder head and intake combination? post or email, jwarmentrout77@gmail.com. Thanks.
  2. 71gold
  3. Powerband
    Powerband Member
    NY's \H/
    You will probably get a lot of "put a 302 in .." but there are many options for the simple 'Log Head' small block six to increase its' performance.
    The only vendor source for a removable intake - aluminum aftermarket head for the Ford small block six recently ended with the owner's unfortunate passing - (Classic Inlines). Perhaps another vendor may pick it up but for now only early Australian six heads and maybe Argentinian versions are the removable-intake alternative.
    But there are other performance options being developed and used by fans of the anvil strong small block six. Mavericks and other Ford six cars explore the options and share help with some interesting engine builds on the Ford Six Performance forums :
    http://fordsix.com/
    [​IMG] . [​IMG]
    [​IMG] .[​IMG]
    [​IMG]. [​IMG]
    have fun
  4. Hotrock
    Munroe Falls, Ohio
  5. jwarmentrout77
    dallas, tx
    70 maverick
    I have a stroked 460, bored, 429 boss heads, mics out at 496. Have an old nine inch, coil overs, and 4 link set up. At some point, I'll put in an 8 point cage, tubs, and redo the tunnel for a linko c3. Right now, just want to play with the stock parts and waste some time (and money). Thinking with the right head work, cam, 30 bore, crank trigger, should be able to pull 350hp out of the I6 if I can find a way to feed the thing. The offenhauser 5970 should work. Just looking for options. Thanks for the help.
  6. 71gold
    what are the options for "crank triggers" for a 200?
    I was about 3K into a 250 (rebuild, cam and header) when I went 302...:yup:
  7. mojo
    What did become of that 250? U sold it or have is stashed away somewhere?
  8. 71gold
    sold the car to Hawko (Terry).
  9. 70GreenMonster
    70GreenMonster Member
    Space Coast, Florida
    We did this to my son's 1965 Falcon 170 six:
    Bored .030, new pistons, new forged crank, all new bearings, timing set, DUI distributor, Bosch double platinum plugs
    1977 250 big log head milled .050 for compression bump , Weber 2 BBL block almost ready to go back in.jpg Big log milled down for high comp..jpg bored .030 and all new pistons and rings.jpg almost everything new.jpg
    My son has put 8K miles on it since the build and it is still awesome.
