Lokar Throttle Cable
Discussion in 'Technical' started by demo913, Nov 23, 2010.
  1. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    I am planning on buying the lokar throttle cable but am concerned about how it will hook up to the gas pedal. What mods are needed to get it to fit correctly like the factory one? Thanks...
  2. Dave B
    When I did mine, I removed the plastic piece that snaps into the pedal arm, and installed it on the Lokar cable, and cut it down to length, and adjusted out any slack.
  3. john T
    john T Member
    coalinga CA
    72 maverick grabber
    its a very simple set up i did it in my maverick mine used the same mounts just make sure you have a CABLE cutter to trim the line. you also need a return spring. i cheated and just looped a .50 spring around the cable and a bolt can post a pic if you would like
  4. bmcdaniel
    bmcdaniel Senile Member
    Yep, it connects right up easily.
  5. mjm0395
    mjm0395 Member
    Everett wa
    1972 Yellow Comet, 1966 Ranchero
    Make sure to get the trans kickdown cable at the same time, it comes with the bracket for both the kickdown and the throttle cable. Real nice set up when done.
  6. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    Mine did not come with a bracket.. Making life difficult
  7. mjm0395
    mjm0395 Member
    Everett wa
    Did you get both trans kickdown and carb set up? You need both to get the complete set up.
  8. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Sorry just realized this thread is 9 months old.
    There are 2 types of throttle pedal arms used in our cars. One has a hole with a slot and the other uses a clevis pin.
