I have been looking for the other pair of 15” ansens for over a year now and I have finally given up. I just bought a set of magnum 400s as they seemed to be the easiest and most likely to not cause issues . Car is a 6cyl, 1970. What is the best size that will fit the rim and car and give a good look? Loads of opinions on here. It seems like 205/70 is what I am finding . I currently have 205/70 on my stock steel wheels, but theu look dumb because the wheel is only 4.5” wide. These new wheels are 6”, so maybe they would look right ?
I have a set of 15 inch Magnum 400s on my 72 6 cylinder with 215-65-15 Cooper cobras and I like the set up quite a bit. Looks like they make them in 215-70-14. If you like RWL tires could be a good choice. If you have the original driven gear for the speedometer cable then you will probably need to change it to keep the speedometer accurate.
215/60 front and 225/ 60 rear on 14's - supercharged straight six / T5 /Bench Seat / AM Radio / : . .. . . . have fun
Too short. Especially the 215. When I had 14-inch wheels, I ran 235/60. They are 25 inches in diameter...
