so im looking for some parts i cant seem to find ive searched everywhere and no one has them ive listed them below they are for a 75 2 door grabber any help is greatly appreciated. weather stripping for both doors all four windows and the trunk the trunk pan as mine has rusted out interior peices trim door panels kick panels dash ect grille hood also i have done a 302 swap and decided to eliminate the power steering originally i was told i could just pull the power steering pump off cut the lines and that was it but is there anything else i need to do to do it correctly again thanks for any help
I have some parts that you need grill, kick panels, hood and a lot of interior parts. There is a wrecking yard that has a mav 4 door I can check how good the trunk pan is. Let me know I'm in Bremerton. email me.
The weather stripping is available new through Daniel carpenter reproductions...Autokrafters...Steel rubber products... Good luck!!!
you can eliminate the p/s by just removing the pump, hoses and ram. but you will have some slop in the stearing wheel due to the pressure valve on the center link not pressurizeing. there are kits that you can put into the valve to take out the slack but the beter way is to put a manual centerlink and pitman arm on to the car. also the power stearing gear box has a faster gear ratio in it that takes more effort than the manual stearing gear box has. so chaning to the manual box would be more correct and give you easyer stearing.
