Loose rocker arm nuts
Discussion in 'Technical' started by pr142, Jul 20, 2008.
  1. pr142
    pr142 Member
    Los Angeles
    After 3000 flawless miles on the rebuild, noticed a loud ticking noise comming from the engine. At first, I thought is was an exhaust leak, but the sound appeared to be comming from the valve covers.
    Removed both covers and found at least two of the rocker arm nuts loose. I have roller rockers, and the nuts are the kind with the inner hex lock thingy....guess I did not tighten them properly.
    Obviously, I will know if this is the problem once I remove and readjust them all....had this happened to anyone else? What kind of noise did it make when it happened??
  2. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    That's prob your noise.
    Reset them all and see if that clears it up... and keep a check on them
  3. pr142
    pr142 Member
    Los Angeles
    That fixed it! What a relief.
  4. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Keep a eye on them, also did you double check all the others? I would run a hundred miles or so and go over again,, if you find any loose, take intake off an look at valve train good. Good Luck!
  5. pr142
    pr142 Member
    Los Angeles
    Yes, I removed all 16 and readjusted...will keep an eye on them. Such a PITA removing the valve covers on that car!
