Losing head gastkets Why??????
Discussion in 'Technical' started by mike75mav, Apr 20, 2005.
  1. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    I have a 75 mav with a 250. Yesterday it started to act up like it had fouled plugs OK I change them and it got worse. I ended up with a dead battery trying to start it. Well today I jump start it and got it running. As the engine was going I notice coolant was leaking between the head and block under the spark plugs. Another dam gasket gone.
    This will be the third time I replaced the gasket. I think the heads some how got warped. Is there something I can do that is temporay until I can do a overall. I have another engine a 77 that I'm planning on replace it with, in the next six months. Can I use a thicker head gasket?
    Any ideas?????
  2. Earl Branham
    Lugoff, SC
    Mike; while you have the head off, take it to a shop and see if it is warped. If so, have them plane the head flat, and it should fix the problem, unless the block has an issue that screws up the gasket. Hope this helps.
  3. Rando76
    Rando76 Member
    Claremore, OK
    Agreed. Surface the head, that may be the problem. Also, make sure you are torqing the bolts evenly (in the correct pattern) and to the correct specs. Are you using new head bolts? If not, try that as well. Good Luck!
  4. stmanser
    Davenport, Iowa
    while the head is off take a long ruler and hold the edge agaisnt the deck surface and make sure there isnt any gaps on the block...deck warp is not common but it can happen... it should always be checked when the heads are off.....afterall...what use is getting the heads done if the block is the culprit....
    good luck
  5. mike75mav
    mike75mav Member
    Bremerton, WA
    Thanks for the advice. I'm planning on doing it this Saturday. Since this is my daily driver I can'nt afford to be down while I bring the head in to shop. But I will use a straight edge to check the head and block. Worce case I'll pull the head off the 77 250 and put it on. I don't know the condition of it put I can'nt be any worse.
  6. MavDuke1973
    MavDuke1973 New Member
    San Diego,CA
    1973 Ford Maverick
    1)first check if the head is warped.Take it to machine shop and have them do it.ALWAYS MACHINE THE HEAD SURFACE WHEN PUTTING ON A NEW GASKET.
    2)Use OEM or Better quality gasket.Stay AWAY FROM FEL-PRO AND OTHER AUTOZONE CRAP...USE VICTOR-REINZ AS REPLACEMENT GASKETS,AND NOW WOULD BE A GOOD TIME TO UPGRADE TO COPPER OR STAINLESS STEEL GASKET.
    3)Make sure the surface or the block and the head is clean and free of ANY DEBREE WHATSOEVER.MUST BE CLEAN AND SPOTLESS,OR IT WILL LEAK AGAIN.
    4)Make sure the block is not warped.
    5)Make sure to torque it to the right factory specs as specified in the book,and DO IT IN SEQUENCES OF 10 FT/LBS.This will get the gasket set gradually,and will not crush it in the process.
    Optional: i found that a light spray of Copper Spray helps seal the gasket good and helps dissipate heat in the future.
    Do it slowly,do not rush anywhere.
  7. MavDuke1973
    San Diego,CA
    1973 Ford Maverick
    Oh yes and use heavy duty NEW BOLTS.DO NOT REUSE 30+ OLD BOLTS.
  8. MavDuke1973
    San Diego,CA
    1973 Ford Maverick
    And have a friend help you as that thing will be heavy as hell
  9. mike75mav
    mike75mav Member
    Bremerton, WA
    Thanks mavduke1973 I did the job Saturday. I had my son help lift that head off. I done this a few times. I took a brass wire bush and used my drill to clean the head and top the values. Than I clean the block and top off cylinders. I used fel-pro gaskets I thought they were good. I didn't take the head into the shop because that would have been to much down time cause I use the car has a daily driver. I hoping this should last be a while until I can start working on the other 250 I have and just do an engine swap.
  10. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    That eas a good tip about 30 yr old bolts.They may not give true torqe reading. IMO Fel-Pro gaskets are fine (perma torq blue).
  11. Aeon 71maverick
    Aeon 71maverick Member
    Brookings, SD, USA
    Maverick, 1971 2Dr, Green. HighPerf 302 & TCI C4. Interior Black.
    just my :2cents:
    i don't recall what series of felpro i used in 302 buildup, but they have held under conditions that i truly expected to blow them. maybe i'm luck
  12. Old Guy
    Old Guy Member
    I agree on the Fel-Pro gaskets, 1011-1 is what I use and have had no problems. Use them on stock compression and up to 14 to 1 ratio's. Old bolts are a no-no, unless checked for stretch, proper head and block prep along with "tapping all the holes" is another good idea. Have even used the 1011's over, in some circumstances, and they still held up fine, jmo.
  13. Earl Branham
    Lugoff, SC
    Dave; I agree. A few years ago, I changed the heads on my 302, and one of the old bolts snapped right off, after twisting and scaring me to death! Anyway, I was able to use an extractor and get it out. New bolts...always!
  14. Jamie Miles
    Hmm, wish someone would have let me know about using new bolts when I had the head off ours.
    I think im going to put new in for the heck of it, where is the best place to buy them? I know Home Depot has a huge selection of bolts and is just up the road. What grade bolts do I need to get? What thread size? 250 I6 engine...
    We've put close to 200 miles on the Mav in the last 3 days have had no problems so far, but I would rather be safe then sorry.
  15. Earl Branham
    Lugoff, SC
    Jamie; don't get generic bolts. Buy a set of head bolts from Jegs, or from Ford or somewhere like that. I think the Mustang houses have them. They are made for it, where the Home Depot bolts are not.
