Lower A arm to Spindle Bottomed out?
Discussion in 'Parts Interchange' started by McToad, Aug 2, 2016.
  1. McToad
    McToad Member
    Omaha, Nebraska
    1975 Maverick 2 Dr sedan
    I just replaced the lower A arms on my mav, and when I looked at the torque specs for the ball joint to spindle it says 60 ft lbs min. When I do that the castle nut is far below the cotter pin hole? Doesn't make sense. In my original A arms, they had a "steel" sleeve or ledge inside the rubber that wouldn't let the spindle completely crush the rubber boot. What am I doing wrong?
  2. yellow75
    Tillamook Oregon
    You can put a hardened washer under the castle nut. It sounds like the taper on the ball joint is too small I know they make a sleeve to go over it
    Static likes this.
  3. McToad
    McToad Member
    Omaha, Nebraska
    Could my spindle be worn that much? The place on ebay guaranteed high quality parts no foreign off shore. Maybe I got had.
  4. yellow75
    Tillamook Oregon
    Doubtful that spindle is worn, lots of differences in years of parts. Nothing is guaranteed in the automotive world. Do you have a link to the part you bought
  5. 71gold
    sounds like wrong part...:yup:
  6. McToad
    McToad Member
    Omaha, Nebraska
  7. yellow75
    Tillamook Oregon
    I would just put the hardened washer under the castle nut, the threads on the ball joint are probably just too long, I would blame it on a manufacturing error
  8. McToad
    McToad Member
    Omaha, Nebraska
    Okay torqued down everything to spec now my new front end is locked solid. Won't move. What did I do wrong? New LCA rebuild UCA new sway bar bushings new strut rod bushings. Absolutely no give or movement. I can jack the entire car from the lower A arm with no movement to suspension. ?????
  9. yellow75
    Tillamook Oregon
    Upper control arm bushing is too tight would be my guess. Are those stock springs ?
  10. McToad
    McToad Member
    Omaha, Nebraska
    I torqued UCA bushings to 35 ft lbs. Yes Stock Springs just sand blasted them and put a new coat of paint on.
  11. McToad
    McToad Member
    Omaha, Nebraska
    Everything moved prior to putting coil springs back in.
  12. McToad
    McToad Member
    Omaha, Nebraska
    Perches are inboard for end of coil spring. I was told that was correct?
  13. yellow75
    Tillamook Oregon
    If I remember correctly you have to tighten the bushings with the car on the ground, loosen them up and set it down
  14. McToad
    McToad Member
    Omaha, Nebraska
    That sounds right. I plan to loosen the LCA eccentric. As well as the UCA outer bushings. My question is how do I torque the UCA bushings after I set it down and retighten them? Do thwy make a torque wrench instead of a ratchet?
  15. mojo
    I don't see how it is possible to torque UCA bushing nuts, once in the towers. I think you have to torque B4 or tighten then in the towers best you can. If anyone has a way to do it otherwise, I wud like to know about it.
