Lowering my car
Discussion in 'General Maverick/Comet' started by ives, Jun 29, 2009.
  1. ives
    ives Member
    ILLINOIS
    1975 comet 302v8
    what do i need in order to lower the car couple of inches? :)
  2. maverick75
    In the front u can cut about a coil and a half,and in the rear install lowering blocks.
  3. ives
    ives Member
    ILLINOIS
    1975 comet 302v8
    were can i find the lowering blocks? for the front, do i have to replace the shocks also for smaller ones?
    In the front u can cut about a coil and a half,and in the rear install lowering blocks.[/QUOTE]
  4. maverick75
    The lowering block kit is avalable in any parts store. And no you dont need to swap out the shocks, the stock ones should work fine.
  5. Maverick Man
    California
    http://www.summitracing.com/search/?keyword=lowering block&dds=1
    i'd use KYB for shocks.
    http://www.summitracing.com/parts/KYB-KG4517/Application/?prefilter=1
    personally i'd put aftermarket coils and cut them instead of the stock ones.
    check this too:
    http://www.maverickman.com/Suspension.html
