Lowering SNAFU
Discussion in 'Other Automotive Tech & Talk' started by Bum's_Steer, Jun 20, 2009.
  1. Bum's_Steer
    Bum's_Steer Member
    Arkansas
    Ok, I recently dragged one of my old driver/beater projects from the weeds to get it back on the road when my youngest son showed some interest in it.​
    It's a 79 Malibu wagon I originally bought for $200 with a blown V-6 (Jiffy-Lube forgot to tighten the new oil filter they installed) I yanked the froze-up 6-er, and bought a nice running, low-mailage '86 305 HO engine a friend had pulled from his Trans-Am for a big block swap....I bolted it up to a TH350 trans from another project, had dual exhaust installed with some glass-packs, and had a fun, low-buck, dependable cruiser for a few years 'til the front suspension got too worn out to be safe, and I retired it in favor of a newer ride and other projects.​
    So, after dusting off the oxidized paint, chasing off the field mice, firing up the motor and giving it a tune-up, the first order of business was to freshen-up the suspension....I had a set of H&R lowering springs I was going to use on my 79 454 Malibu 2-dr. project, and decided to use them for the wagon instead. Now, with the V-8 sitting on the old V-6 springs, the front end already had a lowered rake, but since the front suspension was so sloppy and weak, and the 17" Bullitt wheels rubbed the front fender lips, I decided to install the lowering springs when I rebuilt the front suspension. I went ahead and installed the rear lowering springs which dropped the back end about an inch and a half, and with the front "V-6 drop", the car had a nice stance.​
    Anyways, a week in a friend's garage, I replaced the upper and lower A-arm bushings and ball-joints (the rest of the front suspension looked tight), installed some new shocks, then went ahead and installed the front lowering springs.​
    Now, here's the rub (no pun intended) the front lowering springs raised the front end at least an inch! On the upside, the wheels don't rub the fender lips anymore.​
    So, what do you think? Does the car look lowered?......can V-6 springs under the weight of a V-8 sit lower than with actual lowering springs?​
    It's no biggy really, I still like the stance, and lowering the car was only an afterthought, not my main goal....and it rides and handles so nice now, I'm happy.......but it's not the results I expected with my first lowering job. I'm going to go ahead and live with it....at least until I swap to Corvette rallys or the 16" Trans-Am/Grand National GTA/GNX wheels I have as optional rolling stock....then I'll have to see how they look, and maybe make adjustments from there.​
    Before, with the rear lowered and the stock V-6 springs up front ​
    and now, with lowering springs all around....​
    Next up, the car goes in for minor bodywork, a steel cowl induction hood, and a couple of fresh coats of '08 GM Cranberry paint.
  2. lastchance
    lastchance Member
    Hingham , Massachusetts
    Looks good to me.Had a !980 wagon, great looking car could not stand the lack of power from the v6 and sold it.
  3. don graham
    Looks like a good cruiser.:)
  4. mothgrey
    mothgrey Member
    76 Maverick
    Looks fine to me. And the answer is yes. The new springs are based on a V8 and the stiffness is calibrated to that. The old ones are for a V6 and designed to sit a a specific height based off that weight. Also you need to figure age and wear which can cause the old ones to sit even lower also.
    Ron​
  5. Joe Dirt
    looks level
  6. tim keck
    sharps chapel,Tn
    Looks good,but the front could come down a bit.I love those Malibus.
  7. mavgrab302
    Looks good to me..............
