M2 equiped owners pics?
Discussion in 'General Maverick/Comet' started by Hottrod1991, Jul 31, 2015.
  1. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Anyguys have the rc 107 kit with 2 inch drop spindles?
    Or even stock height spindle kits
    Any pics of ride height
    Stock height oem suspension, top of tire tread is about level with fender lip
    25.7in tire
    Thanks in advance
  2. 71gold
  3. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
  4. 71gold
    how tall are the shackles, they change the ride height?
  5. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I thought about that after I posted.
    There about 4in higher than stock
  6. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Yeah not worried abour rear ride height, just curious about front guys
  7. scooper77515
    RC-106 with 2" drop spindles. Same kit, but without the coilovers.
  8. 71gold
    the higher the rear the lower the front...:yup:
  9. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
  10. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    How much wider do you guys think you can go on the lower control arms
    I really want the wider street rod engineering lower arms with 1 in drop moint to get more suspension travel
    Just not positive if theyll work the the RCM kit
  11. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    You could prob go with longer arms as long as you acct for the tire clearance. What about the upper control arms? You would need to go wider on both unless you're going for that "cambered" look. LOL
  12. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Yeah...not sure how re-engineering an already re-engineered system is going to work out. Everyone making these kits is pretty much designing the whole package around "their" products. Just not sure how interchangeable everything is going to be, and if you're going to get the desired results you're shooting for.
    I did finally put the R&C 107 kit in last fall, and am very happy with the resulting room in the engine compartment. Mine is pretty much solely drag raced though, so we seem to be comparing apples to oranges in the final results column.
    I'd say to call each company and ask...but I feel reasonably sure they're going to tell you they will only recommend "their" products for use lol.
  13. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    Maxx has a good point. I was looking at SPC MII control arms as they are adjustable and offer more Caster/Camber. But these were designed as bolt on parts for an actual Mustang II. Who's to say that the R&C suspension pick-up points are identical to their namesakes suspension design? Just because it bolts on doesnt mean it was designed to work there.
