Magnum 14” wheel tire size?
Discussion in 'Wheels and Tires' started by bryson123, Jun 28, 2018.
  1. bryson123
    bryson123 Member
    california
    1972 MAVERICK GRABBER
    i have a 72 Maverick grabber and I just picked up a set of magnum 14” wheels. I have found a set of new 235/60/14 tires but was wondering if I would run into rubbing issues on the coils etc. everything is stock suspension wise. Any info would be much appreciated.
  2. 71gold
    should be good...have 255x60x15s on 8" rims on mine.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    14 by what? 6? 7?
  4. Craig Selvey
    235/60/14
    I have that size on the back wheels of my car. Might be a little wide for the front.
  5. mojo
    I also, think a little wide on front. I think you will have some rub issues. I have 205*70's on 7" rims and can feel contact w/ inner fender panels on tight turns. I do have almost 4deg. of castor which may have bearing on my issue.
  6. JL Mav
    JL Mav I almost made it to Lake Tahoe
    Douglas county NV
    72 Maverick, 68 Mustang, 61 F100 unibody
    I formerly had those tires on mine. I never had a rubbing issue. I had done the old school lowering with cut coils. I only had 2 degrees of caster and 1/2 negative camber.
