magnum 500 wheels
Discussion in 'General Maverick/Comet' started by maverick7072, Oct 25, 2014.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    im trying to decide what wheel combo I want for my 72 grabber been thinkin gon just doing the magnum 500 wheels 14x6 front and 15x8 rear anyone with pictures to share with this similar combo,car will have balck wall tires with a lowered front about 2-3 inches I love having a rake and smaller tires up front,car is a drak teal green but the car needs a paint job either going grabber blue cause my wife loves that color or the bright red tat came in 72 pictures welcome to help me decide thank
  2. Earplug
    Earplug Member
    Brighton, Colorado
    1974 Comet
    14's front and rear
    z28th1s likes this.
  3. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    thanks ear plug nice comet! as for the question on 14s up front its what I prefer ,I guess I could go with a 15x6 also but I prfer the smaller narrower tire and wheel up front I never liked wide tires up front or white letter tires
  4. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    I'd go 15x7's all the way around. I have 17x8's on my project comet.
    Crazy Larry likes this.
  5. rotorr22
    rotorr22 Member
    Columbiana, Ohio
  6. Mavman72
    Heres a few more...14X7s'
  7. Stefan
    Montreal, QC
    guys, lets stay on topic.
    z28th1s and rotorr22 like this.
  8. CaptainComet
    Getting back on topic ....
    My combo is 15x7 factory Magnums on the front and 15x8.5 Wheel Vintiques on the back. WV remanufactures these wheels, using factory centers and installing them in a new rim. I opted for a backspacing that was close to factory. Another 3/4" outboard spacing would be better to center the wheel and get it away from the spring.
    Tires are 265/50/15 Coopers on the rear. This brand of tire runs small for the numeric size and actually is only about 1/2" wider than a 245 BFG. Fronts are 195/60/15s and are quite short. It would fill the wheelwell better in a 205/60 or maybe 215/60. Then drop the front just a bit more... it never ends.
    Another couple notes about 14 inch wheels and tires .... tires are harder to get in a good selection of performance sizes anymore. Also, if you go with a 14 x 7 or wider wheel, they tend to pass really close to the disc brake caliper on the front. If you jump up to 15s, the added diameter gives you some room.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    That looks really good. I am curious; what backspacing is those 15x8.5s, and what rear-end are you running? DO you have any rubbing on the frame rail or inner wheel house? Is the lip rolled on the wheel arch?
  10. CaptainComet
    I don't recall the backspacing measurement, but I seem to remember that it is a 1/4" more than the stockers that I run on the front. I am using the stock rear axle and 1/4" spacers added. The tires are still closer to the springs and could easily go another inch outboard. I rolled the lip prior to fitting the tires, and it is completely unnecessary. The tires have raised white letters inboard, and if I drive up a sloped driveway, the letters sometimes rub on the inner wheel tub.
    A Granada/Monarch axle would fix this, so would a 69 Falcon (there was one in the JY a while back).... they are 1.5 " wider.
  11. Stefan
    Montreal, QC
    Since that did not work, I removed a bunch of posts.
  12. John Holden
    John Holden Member
    NJ
    Great work! Now hopefully someone can come up with picures of 15" rear and 14" front wheels to help out.
