Manual steering adapters - Junk or not?
Discussion in 'Technical' started by t.ramsey, Oct 23, 2009.
  1. t.ramsey
    t.ramsey Member
    austin,tx
    both
    I'm going to switch my '75 from power steering to manual. I've seen mixed reviews on adapters. Some say they got loose steering and others say they worked great.
    Are the bolt-on adapters better than the ones that go in the existing control valve?
    Are the adapters worth the money or should I spring for a manual set-up?
  2. 71gold
  3. baddad457
    Just me, but if you're gonna do it, do it right and replace the centerlink and pitman arm to manual
  4. ShelbyMaverik74
    ShelbyMaverik74 Member
    Enon, OH
    1974 Shelby Mav Clone
    pitman arm
    i already got the center link and i heard the power box can be used with no issue, but am wondering about the pitman arm all of them say it is for 75 and up i have a 74 what is the difference?
  5. maverick maniac
    maverick maniac Banned
    owensboro ky
    why don't you change the box it is easy and won't have any issues down the road
  6. ShelbyMaverik74
    Enon, OH
    well
    no real reason except i dont have a box and i spent all my money on a new motor and still dont hove the tranny to support it.
    if i could find one on the cheap that would be great since my engine bay is empty it be a cake walk but basicaly i dont want to spend another hundred or so if i dont have to.
  7. Rando76
    Rando76 Member
    Claremore, OK
    The power box can be used, but remember that it's a different ratio. I have a '77 that was converted from power to manual by using the manual center link and it's faster, but STIFF. It's a 250 with aluminum wheels and 195/75 14s on the front. I'm not telling you not to use the power box, just that it will be stiff in low speed situations. I converted my '73 to manual from p/s (a complete conversion from box down) and I can steer it easily with one hand, but it has skinnies on the front too.
  8. maverick maniac
    owensboro ky
    are you near columbus ohio I can bring one I am a vendor there pm me I can ship to
