manual steering is it true
Discussion in 'Parts Interchange' started by maverickpower, Oct 12, 2005.
  1. maverickpower
    maverickpower New Member
    washington
    75 grabber
    i saw a post that said to get from a power to a manual you just take out the power box and lines. is it true? and is it true for all yeras i have a 75 grabber
  2. Mavaholic
    Sorta. By power box I'm guessing you mean pump. You do all that but you should also replace the power valve assembly with one of those manual adapters available from any Mustang supply house. Its the part that bolts to the pitman arm. If the water pump is driven off the same belt as the power steering pump, you will need a different pully set up because of the pump being gone.
  3. 74merc
    74merc computer nerd
    1974 Comet
    I removed my alternator bracket and bolted the alt directly to the head using the spacer for the alt bracket. Lines up perfectly, same as the late sixties Mustangs, Fairlanes, etc...
  4. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Oh, tell me it isn't that easy and I've been wasting all this time looking for pulleys for nothing. :cry:
  5. Grabber-1
    Grabber-1 Member
    long island ny
    71 maverick
    Yeah its that easy pulled a 302 out of my 74 grabber with P/S and put in a 69.5 with out P/S no head adater just the spacer worked great .....sometimes lack of knowledge is a good thing
  6. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    where did you attach the adjustment bracket or did you not use one???
  7. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    I may need to look into this also... havent bolted an alternator onto my car yet... or put the motor in the car.
  8. Grabber5.0
    Kansas City, MO
    71 Grabber
    Well that's certainly the easiest time to play with accessory alignment. :) If I had a spare timing cover I'd have been messing with this long ago.
  9. Yellow72Mavrick
    Memphis, Tenn.
    I did mine today, pulleys lined right up, I bought a after market adjustment bracket hooked it to the water pump and since it was a flat bracket it worked well
    the original bracket has a offset and will not work with this change. But its workin fine and my engine bay has room now....
  10. Grabber5.0
    Kansas City, MO
    71 Grabber
    That's great Jim. But you didn't post the part# and brand? Shame on you. :D
  11. Yellow72Mavrick
    Memphis, Tenn.
    mybad Matt, lol its a Spectre brand part number 42263. It will be a bit long so measure it the same length as the old bracket and cut it. Then drill a 7/16 hole in the end and bolt it up...oh by the way it was $11.95 at auto zone...
  12. Andysutt
    Conway Arkansas
    1972 Comet GT
    Pictures of this? So this isn't a actual alternator bracket, just something universal you have to drilll your own holes in?
  13. Grabber5.0
    Kansas City, MO
    71 Grabber
    Pretty sure it's the top bracket that goes from the water pump to the 7/16 bolt holding the pump to the head.
  14. Yellow72Mavrick
    Memphis, Tenn.
    Nope the top bracket isn't used. the alt bolts right to the far bolt hole near the exhaust manifold on front of head. the bracket I am talkin about looks like a old chevy bracket, its chrome, flat, and curved, old hot rod style...but it works very well. very sturdy...I like it...
  15. Grabber5.0
    Kansas City, MO
    71 Grabber
    That was my second guess! :biglaugh: I think you can actually re-use the old lower bracket, and just bolt it in front of the alt instead of the back of it. Looks like it would work anyway.
