March Serpentine-1670-Belt to use ?
Discussion in 'Technical' started by Comet GT 73, Jun 14, 2007.
  1. Comet GT 73
    Comet GT 73 Member
    Quebec/Estrie
    Comet GT
    I bought March Serpentine 1670 pulley kit on e-bay obviously I don't know which belt number or for which car application. I still have stock 302 alt, alt bracket and damper.
  2. 390S302
    390S302 Member
    Johnstown Pennsylvania
    1966 cyclone & 1974 comet
    Did you get the instruction with the kit? If not march says the simplest way to find out belt size is take a piece of string and measure it between the pulleys. Then just do a search for that belt size may differ with different pulley, and the use of powersteering, and AC.
  3. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I think the instructions say what size belt to use.
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    My March kit told me which belt to use
  5. 71gold
    ..they did that because they knew you couldn't "pull any strings".:D
    ...:bouncy:...
  6. maverick1970
    Missouri
    :biglaugh: I bought mine with no strings attached!
  7. 390S302
    390S302 Member
    Then again I did not buy the 1670 kit. I got the 30180 kit.
  8. Comet GT 73
    Comet GT 73 Member
    Quebec/Estrie
    Comet GT
    Thanks for reply... no instuction in the box I got it used... and my girl friend string it's too small to fit there :biglaugh:
    March answer:
    Unfortunately, I do not have a suggested belt size for that part # due to so many different variances in motors. The easiest way would be to route a string around the pulleys the way the belt would wrap and tie it tight. Then cut the string and measure the length, that will give you a good starting poing. You may still have to try a few different sizes until you get the proper belt.
    Thanks Elijah
  9. 390S302
    390S302 Member
    Amazing they gave me the same answer when I called. Thats why I passed it along.
  10. v8maverick
    v8maverick Member
    Delaware
    1973 Maverick, 1972 Grabber
    I have the same kit but have not installed yet. The instructions mention nothing about belt size, but I did check around on the web and got 38" to 41". You can measure with a cloth tape to get your size or just go to a local auto store and buy a 39" 6 rib belt to see how it fits, might get lucky and not have to take the belt back.
  11. snwbm
    snwbm New Member
    NJ
    73 Maverick Grabber 351W
    I'm still trying to rig my pulleys but I think I am going to give up and order the whole march setup If i cant get mine lined up right this weekend.:( :( :( :( :(
  12. Comet GT 73
    Comet GT 73 Member
    Quebec/Estrie
    Comet GT
    1670 kit lined up right with stock 28 oz damper but it run alt & water pump only...(y)
  13. Maverick Man
    California
    or just get all the sizes within an inch apart so you don't have to make 10 million trips to the parts store! just return the ones that don't work ;)
    it will work... use spacers to line them up ;)
