Master Cylinder
Discussion in 'Technical' started by NewMaverickGuy, Mar 28, 2018.
  1. NewMaverickGuy
    NewMaverickGuy Member
    Birmingham, AL
    1970 Ford Maverick
    How hard will it be to replace the brake master cylinder? No power brake or power anything for that matter. Someone had left the brake line off the front left brake and the brake fluid looks like crap. The master cylinder is also rusty inside and out. im gonna end up replacing the rubber brake lines all around too.
  2. 71gold
    sometimes the plunger is a little tricky to get right.
  3. mojo
    Not that much involved! Remove the clip on the brake pedal, remove lines on MC, remove two bolts holding it to firewall and that's it. Be sure to bench bleed the replacement MC before reinstall. Also, it's a good idea to replace the brake switch while you have the work being done. That way, reduces the probability having to get under the dash again.
    Check your wheel cylinders; If you have rust in the MC, you more than likely have rust there. Too, be on safe side, I would get replacement wheel cylinders while I am working and only do the job once. Nothing more important than stopping and steering -- IMO....
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Pretty easy.
    The hardest part is crawling up under the dash to remove the clip that holds the push rod on the brake pedal. The brake light switch will be on there too.
    71gold and RMiller like this.
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    That gets harder every year that passes!!!
  6. 71gold
    I don't think I have ever put that clip on correctly the first time...LOL
    take a pic before you take it off...:yup:
    mojo likes this.
