Maverick and Mustang windows loose - video
Discussion in 'Technical' started by mrmalina99, Jun 18, 2016.
  1. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    I searched but did not see this issue discussed. Both windows roll up and down easily. The Maverick used to work really good but now I have to guide it a little at the top and it doesn't seal right. Mustang was loose when I got it. Any ideas of what causes this?
    Mustang:
    Maverick:
  2. Craig Selvey
    I couldn't get your photobucket photos to load, but with the Maverick I would think you have a plastic pin that has cracked or fallen out...or broke. Could also be a guide wheel on the regulator. Pull the door panel and I am sure you will see something amiss.
  3. the muss
    the muss Member
    norway
    1970 maverick with 351 w
    Didrik you sort this problem? I have Just the same problem on mine..
  4. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    I have not pulled panel yet, I am worried it will fall apart.
  5. the muss
    the muss Member
    norway
    Hehe ok
