maverick/comet rear end
Discussion in 'Tool & Shop Talk' started by Gary Stewart, Dec 14, 2010.
  1. Gary Stewart
    Gary Stewart Member
    north carolina
    74 comet gt
    bone yard close by has 2 mavericks,,one comet and one pinto.
    i have 74 cometGT3 speed and looking to buy a spare rear..im not sure of the ratio of my rear..325??? my question is ..are the automatic 6 and automatic 8 cyl cars the same 279 ratio???? am i even close??? would i be satisfied with automatic rear in a 3 speed car 302 application or will i have to slip the clutch with the automatic rear...previous owner had 15 inch tires/rims on the rear for a little better gas mileage????HELP!!! thx in advance for info!
  2. bmcdaniel
    bmcdaniel Senile Member
    Don't know about the automatic sixes but my 3-speed six came with a 3.08 rear.
  3. brickyard67
    brickyard67 Member
    lafayette,in.
    71 maverick
    You can guess close on ratio,make a mark on hub or tire and mark on driveshft,count times driveshaft turns to 1 revolution of tire or hub,if memory is right usually a six cyl. had a higher ratio than a v-8< 3:35 to 2:40>higher ratio easier to move from start, bad on gas milage
  4. rthomas771
    I had to ride the clutch with a 3.00 gear in my Falcon. I have to pedal the clutch to get a roll going with a 3.25...this is with a 24.5" tire on a 350-400 lbs lighter car than a Maverick. 3.00 was the lowest 8" gear in a Maverick. The 7.25" could be 3.20:1
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    8" rears only came in 2 flavors for Maverick/Comets...
    2.79 and 3.00, no matter auto or manual. They were equally available.
    If I were you, I'd get one Maverick rear for a backup and look under the Pinto.
    If it has an 8", it will have a good gear. They only came with 3.40 or 3.55 in Pintos.
    Edit:
    I suppose to answer your question, either 2.79 or 3.00 will feel the same when switching from one to another.
    I can't tell the difference anyway...
    Look at the tag on the rear. It is under the car, attached to one of the bolts holding in the chunk on an 8".
    There will be either a '2' or a '3', with a point (.) right after it.
    Then there will be about a 1/4" of blank area, followed by 2 more digits.
    Those 3 digits are the ratio.
    The blank area between the digits (on cars other than the Maverick) can have an 'L' in it, as opposed to totally blank, and that means "limited slip" or 'posi' to use a popular description. You won't find that on a stock Maverick though, they never had the 'posi' option.
    You may see it on other Fords though, even a Pinto/Bobcat.
    It'll look something like this...
    3. L 40
    or 3.40:1 ratio, limited slip.
  6. bri
    bri midnight special
    mission city b.c. canada
    71 comet GT. 414 cu, c-4, 9+, spool 3.25, 35 spline axles, back halved,12 point,,4 whl wilwood discs, 3 link,tubbed. 73 comet sdn 302, 76 comet 2dr 6 cyl, 84 z-28 468. 98 f-150 4x4 5.4, 98 fld 120, 500 detroit. 09 jeep grand cherokee.
    axle code mav. com.
    If i remember correctly..inside the drivers side door jam on the body there is an I.D. sticker , along the bottom of the sticker are several boxes , one of them being the axle code prefix number. number 3 is 279:1 , and number 6 is 300:1 , hope this helps..good luck bri.
  7. maverick75
    Actually you could find a track loc under a maverick. There was a thread a while ago where two cars surfaced as to having one(with pictures). Both cars had special order DSOs.... Also check to see if they have mustang IIs. They could be had with lower gears.
