Maverick height
Discussion in 'General Maverick/Comet' started by rickm, Apr 19, 2010.
  1. rickm
    rickm Member
    Owosso Mi
    I posted earlier about raising the rear of my car because of the look I want. Maybe someone can give me some meassurements and it will tell if the rear is low or not. When I put a tape from the ground to the fender lip at the center of the axles the front and back are both at 26 1/2 inches. Is it supposed to be like this or should the back be a little higher ? This is my question. I have the same tires front and rear so that isn't affecting it. If I had manuals it might show in there if they are the same. Thanks Rick
  2. Dave B
    Mine is 24 3/4" on the front, and 25 3/4" on the back.
  3. rickm
    rickm Member
    Owosso Mi
    Dave Thank you, that 1 inch higher in the rear is what I'm going for. I put on 4 new shocks and it seems to have riaised the front to being level and I want a raked look. wish there was a quick way to get an inch ( said that before )
  4. Bob Wiken
    Fayetteville, Arkansas
  5. rickm
    rickm Member
    Owosso Mi
    Bob GREAT idea I'm on my way to autozone after diner. I let everyone know what I find, Thanks again. Rick
  6. Dave B
    Cutting the front springs is the easiest way. Or for the getto "Old school" we use to use a cutting torch to warm them up, and they would settle...:D
  7. mercgt73
    mercgt73 Member
    Im confused, how would this raise the rear of the car? Our leaf springs hang under the 3rd member. Putting blocks between the perches and springs would lower the rear body.
  8. darren
    Yep that was my thought??? :hmmm:
  9. rickm
    rickm Member
    Owosso Mi
    Yeh I had it wrong in my head, so back to the drawing board !!!!!!!!!
  10. mercgt73
    mercgt73 Member
    I would think your options are:
    Lower the front by heating springs :)16suspect), using coil compressors (again, :16suspect), cutting half a coil or using shorter tires.
    OR
    Raising the rear by installing helper springs, using longer shackles or using taller tires.
  11. rickm
    rickm Member
    Owosso Mi
    Well I pulled the springs, had them re-arced and they added a leaf. Raised the rear 2 inches, so all is well. Thanks for the info. Now I need disc brakes on the front, hope I can find a kit for 4 lug so I don't have to change wheels ?
  12. Shinysideup
    Shinysideup Chillin the most
    town
    car
    Pics of this rake?
  13. rickm
    rickm Member
    Owosso Mi
    Heres some pics, it's coming along pretty good.
  14. rickm
    rickm Member
    Owosso Mi
    The others, I think I'm getting the picture stuff down.
  15. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    Rando76 told me to use 65 mustang front springs they lower the car like 1 or 2 inchs.
