Maverick Polyurethane Bushings
Discussion in 'Parts Interchange' started by osj16, Apr 15, 2019.
  1. osj16
    osj16 Member
    Max ND
    72 Maverick
    Do the bushings for a 69 mustang work for the front suspention on a Maverick. If not, how do I find some poly bushings that work.
  2. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Be very cautious about poly strut rod bushings. Examples abound of strut rods breaking right at the end of the threads because the pivot at the front of the bushing gets bound up too tightly.
    Installation MAY be a factor. Also, I've often wondered if it wouldn't work well to use poly bushings ahead of the crossmember to control brake torque and rubber behind to allow proper motion.
  3. Krazy Comet
    Agreed on poly bushings, my Comet's suspension was so stiff(all because the strut rods were effectively locked in place) it was almost like having solid springs. I pulled them out and tossed them in the trash bin.
    The replacement Moog are a better design than the orig, happy with with them in both my Comet and Cobra Jet.
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The only place I would ever use polyurethane bushings on a street driven car is on the sway-bars.
    They are too harsh and noisy on the street. Of course if it's a race car, that's a different story.
  5. osj16
    osj16 Member
    Max ND
    72 Maverick
    I dont plan on using poly on the strut rod. But, i would still like to know if the conversion works.
  6. Krazy Comet
    AFAIK all replacement bushings, control arms etc for '66-'71 Fairlane/Torino/Cyclone, '67/'73 Mustang/Cougar & '70-'77 Maverick/Comet(OK there is no '70 Comet) are all same. Can toss '75/'80 Granada in the pile as well.
    Note there are differences from '69 to '70 in tie rod & spindle sizes. This includes early Maverick('69½)
  7. osj16
    osj16 Member
    Max ND
    72 Maverick
    Thank you very much.
