Maverick with FMX Trans
Discussion in 'Transmissions' started by dtlcast, Jan 1, 2010.
  1. dtlcast
    dtlcast Member
    HOUSTON
    Hey Guys, I have a 71 302 with an FMX trans...yes FMX trans and need to know if anyone knows what highway gears and performance gears would work best with this transmission? Right now, I have the 2.79 gears and it's running too high...is this right? Need help, thanks.
  2. mojo
    Fmx
    What do u mean running to high?
  3. rthomas771
    The FMX has the same 1 to 1 ratio as the C4 in high gear
  4. PaulS
    With 2.79 rear gears you should be running near 2700 rpm in high gear.
    Are you sure you have the right ratio?
    what rpm are you running at 60 mph?
    what size tires are you using?
  5. baddad457
    With a 26" rear tire and 2.79's you should be turning about 2525 rpms in high gear @ 70 mph. Going to 3.50's will increase the rpms at 70 to 3168.
