Mechanical Fuel Pump
Discussion in 'New Members Forum' started by limolin23, May 8, 2006.
  1. limolin23
    limolin23 Member
    Tijuana, BCN, Mex
    Mav 74
    Hi Guys,
    Anybody know where Can I found the machanical fuel pump exploded.
    I need to assembly my fuel mechanical pump.
    I have a maverick 74 302
    Thanks,
    Limolin
  2. blugene
    :hmmm: You replace the whole unit. Boy, talk about penny pinchin, sheese:rofl2: j/k
  3. limolin23
    limolin23 Member
    Tijuana, BCN, Mex
    Mav 74
    mmhhhh Thanks!!!
  4. limolin23
    limolin23 Member
    Tijuana, BCN, Mex
    Mav 74
    I cleaned my old fuel mechanical pump and I already installed!!!!:29:
    The cars sound good! jejeje.
    Is the first time that I take a one car to verify something.
    I cleaned the caburater and cleaned the fuel pump ;)
    I'm learning mechanical!! :29:
    Cheers from Tijuana!!!!
  5. blugene
    Hmmmm.... Because I don't know for a fact, I question your location due to the suspeciousness of your spelling in speedy gonzales spanish:hmmm:
    As far as your vehicle, I'm glad it's running now/better. Not sure how cleaning the fuel pump helped...:huh:
  6. limolin23
    limolin23 Member
    Tijuana, BCN, Mex
    Mav 74
    I'm Mexican... and I'm so sorry my english!!!
    The cleaning carburater and the cleaning fuel pump help to my car ;)
    Thxs...
    Limolin
  7. limolin23
    limolin23 Member
    Tijuana, BCN, Mex
    Mav 74
    My dear blugene,
    I'm new on this and I want learn every thing about the Maverick! And is my first time that I put my hand in a car.
    See you my friend,
    Limolin
  8. sierra grabber
    sierra grabber Certifiable
    northern nevada
    probably not all parts are always easy to come by either for you? good job rebuilding it(y)
  9. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Usually when I clean car parts I use gas .... what do you use to clean a fuel pump? :) Generally a fuel pump works or it doesn't ... once the rubber bladder inside goes it is done ...
  10. limolin23
    limolin23 Member
    Tijuana, BCN, Mex
    Mav 74
    Is true!! In some cases is very dificult find some parts here in Tijuana.
    I used carburater acid, with this liquid was possible clean the mechanical fuel pump and the carburater also... Only metalics parts.. w/o rubber neither plastic.
    In Cd. Obregon is very easy (680 miles south from Tijuana) far... far away.
    Sorry my english is not good. But I try to give my explanation. :huh:
    Regards,
    Limolin
