Misterious noise
Discussion in 'General Maverick/Comet' started by KYF350, Feb 16, 2011.
  1. KYF350
    KYF350 Member
    Paducah, KY
    1972 Ford Maverick
    Hi Guys,
    I'm new to this forum and I have a question. Every Maverick/Comet I have owned and my family has owned has had a "pinging" noise up front everytime you hit a bump. Kinda like the balljoints are loose. This '72 has that same problem. I checked the balljoints and they are tight. Any ideas? On mom's 1977 we ended up putting Granada upper control arms with rubber bushings in and it didn't help. I thought the rubber bushings would provide some insulation to the noise.
    I checked the balljoints by placing a piece of notched metal under the upper control arm and wedged it on the ledge below the control arm. Tight as a drum. Any ideas would be appreciated. Thanks in advance. Craig.
  2. darren
    Check the bushings in the frame (under rad support) for the strut rods. Get overlooked a lot and dont last too long in factory trim. Moog sells a nice replacement set. DONT use urethane it will snap the rods in time.
  3. KYF350
    KYF350 Member
    Paducah, KY
    1972 Ford Maverick
    Thanks for your reply, Darren.
    I don't think I have EVER changed those. All I've ever done to them is adjust the alignment. On that '77, the car didn't start that until about 32000 miles. I'm sure those are gone. Will check that. Thanks. Craig.
  4. darren
    Your welcome Craig.
    Even if its not your noise it will drive better with new ones anyhow.
  5. KYF350
    KYF350 Member
    Paducah, KY
    1972 Ford Maverick
    Curious about one thing: does the urethane bushings not let the rods move properly? Looks like it would take considerable to "snap" them. Craig.
  6. Bryant
    the urthane makes the strut rod flex more. its even worse if the front end is lowered or the springs are saging. the flex fatigues the strut rod till it snaps.
  7. KYF350
    KYF350 Member
    Paducah, KY
    1972 Ford Maverick
    Well, we won't use those. Thanks for your replies, guys.
  8. KYF350
    KYF350 Member
    Paducah, KY
    1972 Ford Maverick
    Well, got those bushings replaced. Noise is gone. Realigned the front end. Caster was WAAAAAY off. Balanced the tires. Drives good. Thanks, guys!
