Modified shock towers
Discussion in 'Technical' started by 1slow7t, Apr 25, 2007.
  1. 1slow7t
    1slow7t Member
    Puerto Rico
    70 Maverick, 6 cyl/auto trans, soon to become a 351W w/pan fed C4.
    Need close up pix of modified shock tower, both prefferably, and w/o engine if possible.:hmmm:
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Cut out the hole and "fill in the blank".
    [​IMG]Click on the camera icon under my name and info to the left for a few pictures.
    I cut a "V" slot out of the center rib and bent it over to make a smooth transition to the vertical plate.
    There are some good shots of others here who have done the same thing. They'll post up or you can use the SEARCH feature to see if you come up with something.
    Good luck.
  3. spookum72
    spookum72 New Member
    dallas texas
    72 grabber
    cowl hood
    where did u buy your cowl hood looks good. spookum72:drive:
  4. Rick Book
    Rick Book Member
    Thailand
  5. 1slow7t
    1slow7t Member
    Puerto Rico
    Hey Rick, thanks for the pic. How high from the top of the a-arm, you think I should make the horizontal cut?
  6. Rick Book
    Rick Book Member
    Thailand
    It's more of a "whatever looks like a good place to start" type thing and then go straight down with your cut (some even angle back a little but I don't think it's necessary).
    You don't want to start the cut too close to the shock tower plates or go so low that you're into the A-arm structure.
    You'll "just know" where to make the cuts when you get started.
    Good luck.
