modifing the pitman.. yea crazy I know
Discussion in 'Technical' started by flynbrd, May 31, 2011.
  1. flynbrd
    flynbrd Member
    Ok before I go and purchase another pitman I'm toying of modifing my power one. The only difference between the manual and power pitman is the tappering for the ball joint. My crazy idea is to cut the end off flip it 180 degrees and weld it back on. Do you thing a tig weld can hold it together. He mentioned double welding by creating a valley for the first weld. So far the cheapest replacement I can find is around 50$.
  2. injectedmav
    injectedmav Member
    Georgia
    Spend the $50
    If I'm not mistaken, the pitman arm is forged, it would be compromised at best.
    ...it's not worth the risk.
  3. Bryant
    im sure it could be done. thats not an easy weld to do. it should be tig welded with the correct filler rod used to match the material of the pitman arm.
  4. darren
    I'm sure someone on here can help you out with a good used one if need be.
  5. starsky74
    starsky74 Technician
    Hackberry Louisiana
    i would assume forged or case hardened. id spend the money
    on something my life depended on (y)
  6. rthomas771
    The pitman is tempered steel. Getting it hot from welding will make the metal brittle and it could snap into under regular use. It takes a damn good welder to pull your plan together. After paying his fee and having the pitman re-tempered you would be cheaper to buy the correct parts and do it right.
  7. flynbrd
    flynbrd Member
    hmm looks like I'm buying a used one then lol
  8. baddad457
    The manual pitman arm has a ball joint in it. (or was it vice-versa?)You can't weld that in
  9. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    it would almost be like welding cast, just be sure to check for hair line fractures after welding, it happens quite easy when welding that sort of stuff.
  10. 55crownvic
    55crownvic Member
    colorado springs
    That would be more expensive than just buying the correct unit
