monte carlo engine brace bar
Discussion in 'General Maverick/Comet' started by grabber71302, Jul 13, 2007.
  1. grabber71302
    grabber71302 Member
    alberta canada
    maverick grabber
    any one ever install one of those monte carlo bars in the engine compt.like on some of the late 60's mustangs?if so does it make a vast handling improvement?
  2. RabidCustoms
    yes,...and its hard to tell by "feel" alone, but any extra rigidity can only be a good thing.(y)
  3. mavron 70
    mavron 70 Member
    R.I.
    1970 maverick 5.0 t 5 trans 59 ford rear with 4.11 cogs
    what about the export brace? will that fit as well??
  4. RabidCustoms
    neither fits,......I made my own monte carlo bar, as others on here have done.
  5. Mavman72
    I purchased a montecarlo bar for a 70 stang.I had to stretch it 3 inches,no biggie.It fit fine after that.It did make a difference in the steering responsiveness of my mav.Suspension was still original components at that point.That could be the reason I could feel the difference.Your stock export braces are plenty strong for a street car.Unless you plan to do lots of wheels up launches the stockers are fine.
  6. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Yes.
    'Not sure, but it looks really cool.:cool: My sub-frame connectors made a more noticeable difference...
  7. Mavaholic
  8. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    here is the ones i made for mine
  9. scooper77515
    I have one of Fan's braces. It does stiffen the front a bit.
    More important to me...it looks better than the stock flat ones, and they don't nick your knuckles like the flat sheet metal ones. Also, frees up some room under the hood for easier access to engine parts.
    Just all around a better experience than working with the sheet metal braces.
    Did mine in just POR-15 and they ended up looking like they were powdercoated.
