more engine help please
Discussion in 'Technical' started by ford_mav72, Dec 17, 2005.
  1. ford_mav72
    ford_mav72 Member
    Newberry, SC
    Maverick
    Guys,
    I have a question..
    With an engine removed from a car, how would i be able to start it up and everything and run it with it OUT of a car?
    i need STEP by STEP instructions if anyone can help me out with this..
    Kris
  2. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Hey Kris,Are you just wanting to hear it run or actually want it to run for more than a minute????
  3. ford_mav72
    ford_mav72 Member
    Newberry, SC
    Maverick
    basically if someone wants to buy it, i can start it up and everything for them, ya know? so yeah probably more than a minute..
    Kris
  4. hotrod-daddy
    hotrod-daddy Member
    running engine out of car
    Hey Kris, Top off the engine with oil, I would probally change the oil. If the fan belts are on the engine...either remove them along with the fan and pulleys or leave them on and remove the fan,but secure the pulley with shorter bolts.....plug the heater hoses....remove the t-stat....install an extra long lower radiator hose( maybe one for a motor home or a Chevy pickup,yes a Chevy),fill it with anti-freeze then connect to t-stat housing....connect to a fuel supply and the proper battery source.....start and run the engine. I would have a fire extinguisher nearby for safety measure. You can periodically touch the radiator hose,when feels warm consider the motor has run long enough.....Good Luck(y)
  5. Mavaholic
    First of all, you can run it long enough without going through all the cooling hassles to sell it. Just about 15-30 seconds should be long enough to show someone it runs. Electrically, you need a battery. Put a ground cable on the battery and bolt it to the block. Run a positive wire from the battery to the + side of the coil. Take a jumper cable and hook it to the + side of the battery. Take the other end and touch the starter terminal to start. Once it starts, remove the the jumper cable. Dont do the jumper cable the opposite way because it will spark when you touch the starter. If you spark it on the batter, you can blow up the battery. Gasses comming from batteries are highly explosive.
    Make sure the engine is secure because it will try to torque roll.
  6. 71gold
    this is a carbed. motor??:huh: .be careful...be very careful......frank...:bouncy:
  7. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    I almost always fire my motors up on a purpose built stand. It takes about 2 hrs to set one up. However I can run mine as long as I want. Great to break in fresh motors. Good for catching potential leaks or other problems.
  8. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    This may be a given, but it will have to be bolted to a transmision or at the least a bellhousing to have a place for the starter to bolt up, otherwise , like they ^ said.......
  9. ford_mav72
    ford_mav72 Member
    Newberry, SC
    Maverick
    The tranny isnt a problem because I am gonna pull the whole unit at once, but since it wont have an ignition or anything, what would i use to actually start it? I have never done this before..
    If someone could give me a complete write up on this STEP by detailed STEP I would be very very appreciative..
    Kris
  10. Mavaholic
    Is the distributor and coil still going to be attached to the motor after you pull it?
  11. Mavaholic
    Oh yea, is the distributor points or electronic ignition?
  12. ford_mav72
    ford_mav72 Member
    Newberry, SC
    Maverick
    im pulling it as ONE WHOLE UNIT, and im not sure, how can i tell what kind of distributor it is?
    Kris
  13. Mavaholic
    What year car is it comming out of?
