More help haha
Discussion in 'Drag Racing' started by thewest, May 17, 2009.
  1. thewest
    thewest New Member
    tucson az
    1972 ford maverick
    i see this mustang all the time and it always wants to race me but my car cant race haha so i want to fix it up but have no clue what kind of engine to put in it i want to just get a crate engine but idk o its automatic. can someone plz help?
  2. 71gold
    what motor do you have now and does this mustang know?
    what motor does the mustang have?
    ...:drive:...
  3. Bryant
    more info will get you more detailed responces.
    off the top of my head, find a 347 crate motor that makes around 400 hp. get stall conveter from a good conveter company like contenital, or hughes. they will listen to your info and build a conveter that will work best for your car. get the c4 trans rebuilt to take the power level of the motor you get. regear the diff with gears between 3.55 to 4.10. depending on what type of use you plan on. also install a track lock while your haveing gears put in. get some drag radials for the rear. put some subframe connectors on it.
  4. blugene
    And some NOS... :burnout:
  5. thewest
    thewest New Member
    tucson az
    1972 ford maverick
    well i have an inline 6 and no clue about the other car
  6. 71gold
    well....i would find out about his engine first. that way you will know what you need to build to beat him...:yup:
    ...:chirp:...
  7. 73'goose
    73'goose 1/4 mile junkie
    Bay Area, CA
    1973 Maverick
    i would say it would be a good call to go 347, im in the process of building one now
  8. thewest
    thewest New Member
    tucson az
    1972 ford maverick
    is that going to fit? and what would i need to make one can someone like make me a list?
  9. 73rustymav
    73rustymav Member
    clear lake, califorina
    First car in my life 69.5 maverick built 250 inline swap. 73 maverick RIP
    :Welcome:the big parts are v8 frame mounts, belly bar, dual exhaust tranny cross member. a 347 is just a 302 stroked out so it will drop in just fine with all the stuff i listed (warning headers dont fit well with column shift cars and also power steering needs to modified to clear the long tubes.) btw what kind of mustang is:hmmm:? it if its fox body there heaver than a maverick witch is a bounus on your end of the battle!:thumbs2:
    heres a v8 swap link: http://mmb.maverick.to/showthread.php?t=4581
  10. rayzorsharp
    You need to go back to post #3 and decide if you're ready to spend the money needed to do all of this. You're looking at a minimum of $6000...if you're lucky. All the other stuff will be minor things we can help you get together. The money part is up to you. :)
  11. thewest
    thewest New Member
    tucson az
    1972 ford maverick
  12. TrikeKid
    TrikeKid Member
    Roy/Eatonville, WA
    '85 Toyota Pickup, 74 V8 Mav
    The engine isn't the only cost here. You also have to find all the parts for a swap (wiring and everything 73rustymav mentioned) buy a C-4 and build it to suit the motor, stall converter, driveshaft, rear end (gears, limited slip/locker), tires and suspension to keep it hooked up...
  13. 73rustymav
    73rustymav Member
    as everything were saying is take your time,do things correctly, and make sure all parts will work together and not ageist each other. i beleave the best engine would be eather a 331 or 347, less mods needed to drop in the car.
  14. tim keck
    sharps chapel,Tn
    ONLY $5765 and ONLY 350 hp??I believe I'd shop around,find a good builder.A good friend had a 347 built,dyno'd at 515 hp for around $6100.Another friend built a 306 that put out about 400 hp(no dyno on this one)that could be duplicated for about $4000.Both of these engines are pump gas friendly and fit easily since they're both 302 based engines.
  15. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    no.......................
