more help!!!
Discussion in 'Technical' started by stargazer, Nov 16, 2003.
  1. stargazer
    stargazer Member
    Deer Park, Tx
    1970 Maverick Grabber
    Ok guys, I have run into another problem. :cry: Is there some special trick to removing the spindles, or did I just get lucky and get one that is 30 years of stuck together? I took of the tie rod and got the top control arm loose, but the spindle just won't come off the bottom control arm joint...I've tried just about everthing I know to do with no luck. I even tried a puller and ended up damaging the bolt part of the joint :(
    So I also need to know if that joint is replaceable or do I need to replace the whole lower arm?
    Thanks for the help
  2. stargazer
    stargazer Member
    Deer Park, Tx
    Thanks,
    I tried the hammer bit, but not heating it up. Anybody have a lower arm for sale?
  3. Mavaholic
    Do you have one of those tapered forked tools? They are made to remove ball joints. Almost any auto store rents or loans them out.
  4. Wes
    Wes Maverick Police Dept.
    Western Pennsylvania
    '76 Maverick Stallion '76 Maverick Metro Police K-9
    Heat is very useful for unsticking rusted parts like these. A hand held propane torch will not get hot enough. You'll need oxy to get it hot enough. The pickle fork is also quite essential. When Scott and I pulled a front end apart for the spindles and p.s assembly, we ran into the same problems. We didn't have the luxury of having torches at our disposal. A lot of elbow grease and a pickle fork made the difference. They make a pickle fork for air chisels which can be useful if you have a compressor available. I have to get me one of those for my chisel one of these days.
  5. Wes
    Oh, hey Stargazer, they still have new lower arms available at NAPA. I bought a set for my 4 door just this summer. If you can't find them, I can get them for you.
  6. stargazer
    stargazer Member
    Deer Park, Tx
    Thanks again guys, I used a pickle fork with no luck...I think I'll hunt up my local NAPA store and get a new lower arm and be done with it.
  7. Mavaholic
    Your not hitting it hard enough or dont have the right hammer. Get a least good 5lb maul
  8. slowcomet
    slowcomet Member
    Ca
    1975 Comet
    What he said.
  9. 71gold
    claw hammer no! no!no! no! noooooo!!!!!:D :D :D ...frank...:bananaman :bananaman L.T.N.G.
    as dennis, said you need a texas size hammer:smash: :smash:
  10. Old Guy
    Old Guy Member
    One other trick I have used is to drive the pickle fork in and then put a piece of pipe over the handle. Have one of your daring friends stand or push on it while rapping the spindle area with a ball pien or large mallett. Normally leave the ball joint nut loose but if your threads are damaged, watch out when it lets loose. Tools and helpers may scatter in all directions. :clap:
  11. jayman
    jayman Member
    San Diego, Ca
    69.5 Maverick/72 Grabber
    There is a real nice tool specially made for pressing balljoints and tierod ends out. It cost me about $45 for the tool at AutoZone. I figure that using this tool has saved me hundreds of dollars in damage that I would have incured using a pickle fork and hammer. :eek:
    Every classic car nut should have one of these....just to save the frustration and bruised knuckles.
    --Jay
  12. stargazer
    stargazer Member
    Deer Park, Tx
    thanks, Jay I will look into the tool at Autozone...
