More power...
Discussion in 'General Maverick/Comet' started by gtpictor, Aug 21, 2009.
  1. gtpictor
    gtpictor Member
    chicago
    maverick
    Was wondering what i could do for cheep to my mid 80's 302 to give her some power. I allready have a edelbrock performer intake. Hooker hearder with a dual 2.5 inch exhaust, 3.80 rear end with a posi. Thank you for your suggestions.
  2. 71gold
    HP=$s...how much more power do you want?
    how much more money do you have?
    ...:yup:...
  3. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    a set of e-7 or gt40 heads and a mild cam i have a e-303 in mine with a set of ported and polished e-7 heads and a good holly 600
  4. gtpictor
    gtpictor Member
    chicago
    maverick
    about a grand
  5. starsky74
    starsky74 Technician
    Hackberry Louisiana
    decent set of aluminum heads. thatll do it
  6. mean_maverick
    true, but he'll need the other parts mentioned before the heads will work to their potential
  7. 302-72-mav
    302-72-mav Member
    sactown CA
    the gt40 heads are from a 351 witch you will have to get a new intake and then the heads will be as close as a 351 in there so u will have to spend some serious cash for a set of headers ? $$$$$$$$ might as well put in a 351
    i put a t5 in my car with a 12 pound flywheel way better it wakes the car up and gave me a smile and i don't have a 4bbl carb yet ! :thumbs2::burnout:
    look at my post's and you will see what all i did to swap the t-5
    or a B&M shift kit i put one in my c-4 and first gear shifted at 35 second at like 60 i think ? when you punch it
    port your heads i did mine with a nibbler bit and used a air gun NOT HARD !
    MSD distributor // or a points eliminator kit i used a the ACCEL kit with the MSD blaster 2 coil $ 115 out the door at kragen/oriley autoparts i noticed a lil bit of a diffrence idel's smoother and better responce but if i was to buy one again i whould buy the petronex one cost more $
  8. Joe Dirt
    The heads do not make it wider.The block deck on a 351W is taller giving the extra height and width.A 302 intake will work fine with 351W heads on a 260/289/302
  9. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    GT40 head aren't from a 351 there from a 302,mine came of a 93' cobra,i know you can get gt40p's of exploreers but idk about normal gt40's.
  10. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    regular gt40 come on 96 and early 97 explorers
  11. Bryant
    id put a higher stall converter in. all these other mods will move your power band up. that takes power away from the low end and you will find out that the car doesnt jump up and go like it used to. a 2500 to 3000 stall speed should be close to what you will need with the cylinder heads.
  12. starsky74
    Hackberry Louisiana
    a converter would be a nice addition, but i still maintain a set of decent aluminum heads.. better cam and thatll get u where u need to be, that should add at least 50 at the wheels, then when u do something w the short block..you will allready have a good set of heads for it! what else could make an actually 50+ hp tq at the wheels.. for the same buck? besides spray and be good for future build??
