More project pics
Discussion in 'General Maverick/Comet' started by Racer_X, Jan 27, 2011.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
  2. mojo
    What's in the metal box on the fenderwell?
  3. justin has a 74
    kentucky
    Hey, i want my valve covers back:D
    Looks great:yup:
  4. Racer_X
    North Carolina
    lol thanx.
  5. Racer_X
    North Carolina
    its a dooms day device lol. lol inside the box is the accel gm module i installed. the box and fins are aluminum to keep it from overheating
  6. Awesome_X
    Awesome_X Member
    Oklahoma
    What does this do? At first I thought it was the coil but then I looked again and I could see the coil in the background.
  7. maverick75
    The module is the brains of the ignition, its the same thing as a duraspark box. Looks great Racer_X :)
  8. Racer_X
    North Carolina
    Thanx, i just finished test fitting the alternator that i got from the junkyard and it fits perfectly, I wil try and post some pics of that between now and monday i also made up some brackets for the engine oil cooler too (below)
  9. mojo
    So by using the "GM" module outside of the Dizzy one can eliminate the DuraSpark box/module? If so I'll have to familiarize myself w/ this setup.
  10. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Looking good.
  11. Racer_X
    North Carolina
    its actually very easy to do
  12. starsky74
    starsky74 Technician
    Hackberry Louisiana
    cool:thumbs2: looks good
  13. Racer_X
    North Carolina
  14. injectedmav
    injectedmav Member
    Georgia
    Looks good!
    That alternator is a Beast! Left my lights on and killed the battery one day and was in a hurry to get home, so I figured I would jump it and charge it when I got there. Well, the 16ga fuse links(2 in parallel just like factory) I used looked like someone used them for welding wire by the time I got it in the shop. If you haven't thought of it already, I would use a good pair of 14ga fuse links in parallel(what I have now) or a cartridge style fuse(~185amp or so) just in case. My alternator was charging @ 135amps with a dead battery! :D
  15. Racer_X
    North Carolina
    thanx i will have to remeber that
