More sway bar info I6 vs V8 any of you notice the same thing?
Discussion in 'Technical' started by Maverick Man, Jun 11, 2005.
  1. Maverick Man
    California
    hum something i noticed today while putting on my 7/8 bar on my I6 maverick.
    Now i know why thats the only size they make for a maverick. i know it was meantioned that you could order a 1-1/8 custom or put 1 inchers off a mustang on a maverick (http://mmb.maverick.to/showthread.php?t=16175) but i know now the reason why 7/8 is what they carry in stock only.
    anyways after putting the 7/8 bar on my I6 maverick i noticed there is less then a 1/4 clearance between the swaybar and oil pan. where as a V8 has plenty of room. so if you put a incher on it will for sure hit the pan.
    just something i noticed. anyone else ever notice that? or is it just me?
    either way just an FYI if anyone desides to do a 1 inch or bigger on a I6
  2. stmanser
    Davenport, Iowa
    well if there is 1/4 inch clearance....the 1 inch is only 1/8 thicker than the 7/8....and thats outside diameter....so the clearance will be 3/16 from the oil pan now instead of 1/4.....
    you could also put washer between the sway bar mount and the bushing clamp...that would keep it the thicness of the washer lower ..... i have heard of people doing that...it sounds a little southern rigged....but it works fine from what i understand...
    and i definetly need the larger sway bar on my car....i never upgraded the sway bar after the engine swap..and i can feel it swaying awful bad...
  3. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    'Southern Rigged'?
    Where are our Gawja boys?
  4. stmanser
    Davenport, Iowa
    southern as in kentucky and tennessee....hey what ever works ...right?
  5. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    You are correct, however the 3/4" bar was standard while 7/8" was optional...so they actually made two bars for the Maverick. I "believe" that '75 was the first year that the 7/8" was offered from the factory, but I could be wrong...
  6. RRS4USA
    RRS4USA Member
    Aiken, SC
    71 Comet GT
    Sway Bar
    OK, so which Mustang bar fits the Maverick? I am guessing the 1-inch '65-66 Stang bar?
  7. MiteeMaverick
    MiteeMaverick Senior Member
    Jonesboro, AR
    1987 Mustang GT Convertible
    Hey, I resemble that remark !
  8. Maverick Man
    California
    yes your right with the math.. but you also gotta consider when you jack up the car the swaybar moves. when i jacked the car up the bar pushes agaist the oil pan... if it was one inch it would for sure dent the pan. maybe thats why it was an option.... or maybe it was only an option on a V8... just a thought.
    either one will fit.. you just gotta make if fit right. ;)
  9. tim keck
    sharps chapel,Tn
    So what are you tryin' to say,that a Havoline overflow tank(jug),log chain around the drivers motor mount,shackles & coilovers to help weak springs are "southern rigged"??:confused: Hey it worked(sorta)!(y) :biglaugh:
  10. Cleaver
    Cleaver Member
    MD
    Chel
    Southern rigged.........I resemble that remark :biglaugh:
    Cleaver
  11. Burlap1
    Burlap1 fat lazy truckdriver
    Urbana ny-wine country finger lakes wines are best
    1983 f-150 4wd,1971 cougar parts car,1973 maverick parts car,1970 maverick formerly a gramma's grocery getter,1984 f-250 460 powered,1976 f-350 u-haul,and some chevy's
    :clap:Not to steal the thunder from under but we in the north have been known to use similar techniques.that log chain and a little duct tape isn't just for use with hamsters anymore!!!:biglaugh::yup:
  12. RRS4USA
    RRS4USA Member
    Aiken, SC
    71 Comet GT
    Hmmm...
    LOL. Now thats funny I don't care who you are!
  13. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    still trying to figure out what southern rig means...uhhhhh i have heard of jerry rig... is this supposed to mean johnny rig?i have also heard of uhhhh well the n word rig ( not too cool in my opinion...) but southern rig? i always thought that a southern rig was a pete or frieght with lots of chrome...and NO RUST...
  14. Burlap1
    its got to be a southern thing i guess?most likely just like them grits what the heck are those anyhow?
  15. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Derrick can you shed a little light on what you mean by gotta make it fit?
