Mr.Gasket fuel pump
Discussion in 'Technical' started by Racer_X, Jan 19, 2013.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
  2. baddad457
    Can't answer that, but I've got one of their 12S pumps feeding my 331's 3x2 setup. Been there now for about 6 years. Never missed a beat.
  3. rthomas771
    I can't answer that either...but it says "Not compatible with alcohol or methanol fuels". That being said...isn't ethanol and alcohol in the same category as far as corrosion goes? I notice the 12S is compatible with "All fuels and additives"
  4. Joe Dirt
    ethanol is alcohol
  5. 71gold
  6. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    Most gasoline nowadays is 10% alcohol.
  7. baddad457
    If I'm not mistaken, Methanol is more corrosive than Ethanol. I'll have to look it up in my hasmat manual. They're both alcohols, but not the same.
  8. Racer_X
    North Carolina
    midgrade lol.......
  9. baddad457
    Midgrade could have either more premium mixed into it to boost the octane, or more ethanol. Both are used to raise the octane of the base fuel. Our conventional gas is a mix of 84 and 91 to make it 87. The 87 octane ethanol mix uses ethanol to raise the 84 to 87. I've been mixing 93 octane ethanol mix with conventional 91 in my 331 for two years now and it hasn't had any negative effects to either the pump or carbs, and it sits for weeks at a time allowing the fuel to evaporate in the carbs.
  10. Racer_X
    North Carolina
    thanx for the info, how do you have the 12s mounted? is it above or below the fuel level of the tank?
    i have a bosche in line fuel pump (cant find any info on this pump) but i dont know if i can mount it above the fuel level, looking for sumthing that can be mounted obove the level of the fuel
  11. baddad457
    It's mounted on the inside of the frame rail, forward of the rearend. It's drawing from the stock fuel line, I simply cut the original fuel line and spliced in the pump using rubber fuel hose. I spliced in a std 3/8" fuel filter between the pump and tank line to keep any trash out of the pump. The only time the 12S fails to feed the carbs is when that filter gets clogged. That's when I know it's time to change the filter.:idea::D
  12. Racer_X
    North Carolina
    oh ok kool, I'll give it a try then
  13. Joe Dirt
    mine is mounted underhood
  14. Racer_X
    North Carolina
    do you have pics of how its mounted under the hood?
  15. Joe Dirt
    on my six it's on the powersteering bracket
