MSD setup
Discussion in 'Technical' started by yellow75, Jul 12, 2009.
  1. yellow75
    Tillamook Oregon
    For the people that are using a MSD 6AL and a MSD distributor what coil are you using, in previous set ups I used the Accel super coil but want to get away from the bulkiness of it and was just wondering if the MSD blaster 2 coil is sufficient for good spark.
  2. Mercurycruizers
    Venetia, PA
    If you would've said something yesterday when you were here. I could've showed you the Comet. I'm using the MSD distributor with the 6A MSD box. I'm using the Master blaster 2 coil....
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I have a MSD Blaster 2 with the MSD Distributor and 6AL.
  4. Mavman72
    I have a 6AL box and blaster 2 coil on the Sprint...works very well...
  5. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    I used to have the MSD Distributor with vacuum advance, 6a box and Blaster II coil on the F100 when it had the 351W in it. I also had the timing control where you could adjust the initial timing going down the road. Worked very well.
    I sold it all with the Windsor when I went to a 460. I now run run a Duraspark with HEI 4 pin module and Accel coil and it runs about as well. I have burnt up one coil though. Not sure why.
    The MSD will sure punch you back against the wall when you get in it's way though, I'll tell you that. lol
    clint
  6. yellow75
    Tillamook Oregon
    Thanks for the info guys, I just didnt know if the blaster would be hot enough. Guess I better get one of them, then some spark plug wires and a torque converter and I think my buying spree will be over. Hopefully
  7. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
  8. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    I have used a Blaster 2 and also a stock duraspark coil , hard to tell the difference between the two,it seemed to run the same.
  9. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Blaster 2 with a 6A in my son's car. It has been a very reliable setup.
  10. Centerline
    Centerline Member
    Washington State
    1971 Ford Maverick Grabber
    My Blaster 2 coil and MSD6AL has been great. That thing will throw a long arc.
  11. tim keck
    sharps chapel,Tn
    I ran an Accel SuperStock coil(looks like a stocker,only yellow)and cracked it during an intense head gasket swap at FFW in Atlanta,found an old stock coil & used it.Worked fine,couldn't tell the difference:rolleyes:.Oh yea,I was running the MSD 6AL box at that time.
  12. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    I believe I've read somewhere that either Accel or MSD specifically mentions the Accel SuperStock coil as one not to use with a capacitive discharge box... As for me, I'm using a no-name HEI coil with my MSD 6A.
  13. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Blaster 2.
  14. Scotty P
    Scotty P Member
    santa rosa, ca
    Mallory Pro-Master for me
  15. rthomas771
