Muffler questions
Discussion in 'Technical' started by littlecrow, Dec 10, 2009.
  1. littlecrow
    littlecrow Member
    Caneyville, Kentucky
    1970 Ford Maverick
    Hey every body, I'm looking for a decent muffler for my car that doesn't break 103 decibles but still sound good, I'm not a big glass pack kind of person, the car is a 200 l6 using stock manifold. This is an odd question since every were I look people are trying to go louder, but I can't break 103 decibles. Thanks.
  2. Boosha
    Boosha Built to run hard
    Buckeye State
    69.5 Maverick,1964.5 Mustang,1966 T-Bird
    the cherry bomb turbo muffler gives a nice mellow rumble.about $30 at autozone.
  3. Jeff S
    Jeff S Member
    NoVA
    none
    Can a 200 get that loud? I ran around for a little while without a muffler on a 250 and it wasnt horrifically loud...Id assume any muffler would be good.
  4. littlecrow
    littlecrow Member
    1970 Ford Maverick
    thanks, I'll look into that.
  5. Craig Selvey
    My opinion, just get a normal muffler. A 6 cyl engine with any type of performance muffler sounds obnoxious.
  6. rthomas771
    True with stock exhaust...but with headers, divider plate and cam...it will sound like a V8. Check out the sound on this 6 cyl. http://1bad6t.com/sec/images/BobbyB/Bobby.wmv
  7. littlecrow
    littlecrow Member
    1970 Ford Maverick
    Does anybody make larger cams for a 200 or are they custom?
  8. rthomas771
    Compcams, Crane Cams, Clifford Performance, Ford Six Performance, Isky Cams and Schneider Cams.
    If you want to hotrod a 6 cyl...I'd recommend getting the Six Cylinder Performance Handbook by David and Dennis Schjeldali http://falconperformance.sundog.net/
    It is full of tricks and tips
  9. littlecrow
    littlecrow Member
    1970 Ford Maverick
    I've found headers, it's just says there for off road use only, why is that? Add a cat and it would be better fuel economy and emissions I'd think.
  10. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
  11. rthomas771
    I think ALL header say that on the box. Adding a catalytic converter will restrict the exhaust flow and might hurt gas mileage.
  12. littlecrow
    littlecrow Member
    1970 Ford Maverick
    Does anybody know what kind of fuel mileage increase, if any, I would get from just headers and a larger exhaust.
  13. Positively Ralf
    Yonkers, NY
    1974 Maverick
    Not much at all. But they are the basis for future mods.
  14. baddad457
    X 2 ! It'll sound better with straight pipe.
  15. baddad457
    That was only at idle. Open it up and it sounds nothing like a V8. I've heard several sixes with both split headers and turbos or glasspacks, they all sounded obnoxious. They're far better sounding with just straight pipe (all the way out the back) and no muffler.
