my 71 maverick grabber
Discussion in 'New Members Forum' started by MichAnJD, Nov 27, 2013.
  1. MichAnJD
    MichAnJD Member
    california
    1971 maverick grabber
    heres a couple of pictures
  2. MichAnJD
    MichAnJD Member
    california
    i'll be putting it back together with mercury comet parts
  3. MichAnJD
    MichAnJD Member
    california
    does anybody did a 8.8 rear end swap without doing anything on the rear end?
    i want to put 8.8 in the car i got the rear end.
  4. MichAnJD
    MichAnJD Member
    california
    radiator
    fitting good there.
  5. rriott
    rriott Member
    Dana Point, CA
    72 Mav
  6. mav1970
    I think that you will do well considering that the body shell is in such good shape :yup:
  7. braess
    braess Member
    Buchs Switzerland
    Ford Maverick GT 1974
    yes got one in, but didnt drive it yet.
    96 explorer, 3.73 posi, cut around 3" off the long side, put other short axle shaft in, welded new leaf spring supports on, adapted sway bar, and all new brake lines, bearings and everything...
  8. MichAnJD
    MichAnJD Member
    california
    yeah i got the rear end from 97 explorer is it gonna fit without cutting it?
  9. mojo
    I am wondering if that fan setup is going to be up to the task keeping the car cool w/ so much of the core not in position of having air forced through it. If it's a street car; I believe it will have issues in slow summer, city traffic.
  10. junrai
    junrai Member
    rancho cordova ca
    those fans are going to be in addition to the belt driven fan on the other side of the radiator. I doubt they would come close to handling the job alone.
  11. Dave B
    Nope, you need to cut it down.
  12. bmcdaniel
    bmcdaniel Senile Member
    They also block a lot of the radiator.
  13. 71gold
    nope...too wide and needs spring perches welded on.
  14. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Cool car, and almost the same color as mine (maybe a tiny bit darker).
  15. Red1972Grabber
    Northern California
    Nice score Curb Hopper!(y) Although it would be better with a Grabber Hood and Grill.:stirthepot:
