My 74 Maverick
Discussion in 'Maverick/Comet Projects' started by fastback86, Aug 4, 2009.
  1. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    I'll add to this as I have time, starting in the beginning when I went for a looksy...
  2. Bob Wiken
    Fayetteville, Arkansas
    Looks like a project. What are your asperations?
  3. fastback86
    FL
    Those first photos were from over a year ago. I'm looking to make a very fast hot rod.
    Here's a few more from when I went to look at it. Inside was packed full of parts Orignally a 250 six, previous owner had "good intentions."
    That steering wheel has come back to haunt me. The '69 Mustang I had that I never did anything with had the same one. Hated it then too. Just not for me.
  4. fastback86
    FL
    Some photos after I got it home and got it cleaned out. I have no idea what the seats are out of. They're welded in. There's lots of custom work like that done. Pay attention to the rear bumper.
  5. 1973Maverick357
    Cookeville TN
    Wow that guy loved spray paint and messing up cars thats really good of you to restore this idiots work because i know alot wouldnt put that much effort and would scrap it.
  6. Joe Dirt
    reminds me of my 74 when i started
  7. fastback86
    FL
    Just like some people shouldn't be allowed to use tools, there are some that shouldn't be allowed to use spray paint. Here's some more photos shortly after I got it home. Engine is straight out of '91 Mustang, pan and all. Note the custom engine mounts. Also was not bolted to the tranny properly (hmmm, wrong flexplate?).
  8. fastback86
    FL
    After about 6 months of rounding up engine mount brackets, intake, exhaust manifolds, accessory brackets, and late model Mustang wheels. Front bumper is held on by zip ties (no brackets yet), I straightened the rear bumper quite a bit, moved it up to where it's supposed to be. I have the wrong brackets here, it sticks out too far.
  9. mavgrab302
    Wow what an improvement..looking good
  10. Shorty
    Shorty Member
    Lafayette, In
    Wow! Hard to believe it's the same car. Excellent work!
    Bruce
  11. fastback86
    FL
    Thanks for the compliments! I still have a long way to go but certainly more presentable. I can't believe what a difference a good set of wheels makes!
  12. fastback86
    FL
    Here it is in its current state. New leaf's and correct shackles, 9" rear from a '73 Mustang, disc brakes on all 4 corners. Rear bumper has correct brackets, removed bumper guards, correct rear 1/4 caps, rear valence installed and license place mounted properly. I made brackets for the front bumper. Put a cheap coat of tractor supply paint to cover the primer until I can give the body more attention. Hard to believe I've had it for 13 months now!
  13. mavgrab302
    Looks great...........
  14. coutangman
    coutangman Member
    Charlotte, NC
    Great job on the car. Did you have to modify the 9" rear end or did it fit ok as is? I thought they were too wide for a Maverick.
    Where in Fl are you located?
    Jim
  15. fastback86
    FL
    Ahh yes grasshopper, you are correct! Those wheels are from an '08 convertible Mustang. Before I swapped the axles I had to run spacers behind them. The axle fits fine, it's just wider than stock but since I have late model wheels everything's ok. I still have spacers behind the front wheels though. I'm in Deltona, about a 2 hr drive from you.
