here in the next month or so im plan on rebuilding my 302, its gonna get a pair of ported an polished heads and a mild cam. i may put a t5 in it too with fox body petals. i also have access to a m2 front end and 9in rear with all disk breaks still on the frame all for 100 dollars and its all in good condition. so i was thinking bout getting the welder series m2 crossmember kit, with this crossmember kit would the m2 supension cut weld and bolt together pretty easy? if i ended up not using the m2 would the disk brakes still swap over? and would the disk breaks off the 9 in work on the 8 in? in amongst all this i want to make the engine compartment look emaculent. probly a monte carlo bar an make new braces. wut all i actually do depends on budget and tools services availible any thoughts or ideas appreciated
