My Mav on the scales
Discussion in 'General Maverick/Comet' started by GrabberGT, Oct 23, 2010.
  1. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    I asked her what she weighed today and got slapped pretty hard. She weighs 3350 with me in it (180#) and a full tank of gas (100#). The good news is my Front to rear balance is 51.4/48.6 with a cross weight of 49%.
    Ttl 3348
    LF 884 RF 839
    LR 811 RR 814
    Front total 1721 51.4%
    Rear total 1626 48.5%
    Cross 1641 49%
    I need to find a way to get her to drop a few lbs but Im not sure were to start and dont want to make any drastic changes like a full tubular front end. I'd prefer to remove weight from the front end and not the rear but theres not much I want to sacrifice up front. Ive already got Alu heads, intake and radiator. I want to keep my power rack/pinion and AC. Its got tubular upper and lower control arms as well as coil over shocks. I might replace my rad support with an aluminum one but I dont see that saving much weight. I could pull up the sound deadener (peal-n-stick) and go back in with lizard skin but thats a bunch of work and I'd only save 25lbs or so. Im planning on going to 18" wheels but the rumor is that will add weight over 17's. If I did all of these things and find a way to get a Carbon Cowl hood from MaverickMan (shipping issues) I might be able to shave 100 lbs off the car. That wouldnt be too bad. Anyone have any other ideas?
  2. don graham
    Sounds like you're not going to lose much more. Have you thought about moving the battery to the trunk. No savings bit it shifts the weight.
  3. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    Thanks but its already in the trunk.
    Im starting to wonder if the weight he put in the seat was really 180 lbs. Maybe he miscalculated. According to http://www.fordmaverick.com/yrtoyr.htm the 1972 Maverick weighs in at 2736. I've made quite a few weight saving mods and added weight to the rear and mid sections for added chassis stiffening. But the net added weight couldnt be 300+ lbs could it? My suspension system with added chassis components weighs maybe 250 at most but displaces 120 lbs. How much does a 9" weigh over an 8"? Thats another source of added weight.
  4. mav1970
    If you were running circle track with your car, from your numbers, I would say get your battery into the trunk to get the LR number up, jack 2 turns into the LR, 2 turns into the RF, take 2 turns out of the RR and pick up the panhard bar. Get that cross weight up to at least 52% or you'll be loose in the turns :biglaugh:
  5. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    LOL
    Curious and I didnt think about it until now but is RF and RR the Passenger side front and rear? From a balance standpoint should I try and get the LF and RF as equal as possible? I so I should raise the LF to add weight to the RF and raise the RR to add weight back to the LR. Hmm this gets confusing pretty quick. :hmmm:
  6. mav1970
    The RF & RR are on the passenger side of the car. Right and left is determined by standing behind the car and looking towards the front. I figured that you were using a set of electronic scales and the cross weight is needed for circle track racing. Low % the car is loose in the turns - too much crossweight, it will push in the turns. Sorry I can't help you with what % you would be looking for on a street car. I do know more rear weight and less front weight is always desireable but you can't move your engine back in the chassis and that would certainly do it for you.
  7. 302-72-mav
    302-72-mav Member
    sactown CA
    what about lighter heads ( not sure what you got up there )
    or you can make up for the extra weight for extra H.P :)
  8. darren
    Sounds a bit heavy to me??? I guess when you add the 9 inch,sound deadener etc. it adds up. :huh:
  9. maverick maniac
    maverick maniac Banned
    owensboro ky
    the hood seems to be the best option ,,,,
  10. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    I would say trust your scale guy, trust the numbers. You have the right weight on the car with chassis stiffening and rear end, now just take the un needed weight out of the car. ;)
    Aluminum heads
    aluminum intake
    drag wheels
    strip accesories
    light weight brakes
    racing seats
    fiberglass hood
    fiberglass deck lid
    strip door bars
    rear seat delete
    strip sound deadening
    fuel cell
    lexan glass
    aluminum drive shaft
    fiberglass bumpers
  11. scooper77515
    Seems kinda heavy. Mine was right at 2980 with me in it, full tank gas, tool box, and slicks in the back seat.
    I was 200 lbs at the time. So 2780 car alone.
  12. mav1970
    An aluminum radiator would also be a big weight saving item. Other than the front bumper, that is the greatest weight that far forward in the chassis.
  13. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    I've already gone thru the Engine comp and swapped out heads, intake, waterpump, and radiator for their Aluminum counterparts. Battery is in the trunk and the battery tray has been removed.
    Its a family cruiser/auto-x car so creature comforts need to stay. I can drop 100 lbs pretty quickly with a hood, Aluminum core support, lighter racing seats, lighter wheels and removing excessive sound deadener.
    Scoop, I'd love to see your car and find out how it could possibly be soo light. Maybe seeing a Mav close to stock config and comparing it to mine will help highlight where all this weight came from. I guess over the years of modding, all the "oh its just 10 more lbs's" has finally caught up to me. lol
  14. scooper77515
    All i have done that shaved weight was go small bumpers, alum radiator, and one 73 door that does not have the cross beam inside.
    I have sound deadener under all carpet, inside quarters. I really was not attempting to lighten the car.
    My weight was taken at a landfill ramp. I wasnt sure if it was accurate so i stepped on it without the car and it said i weighed exactly what my home scale said. So i assume the car weight was accurate.
  15. mav1970
    Chris, this might seem like a dump question but did you zero the electronic scales prior to putting your car on them?
