name of paint?
Discussion in 'Cosmetic' started by pitbull12888, Jul 3, 2008.
  1. pitbull12888
    pitbull12888 Member
    waxhaw, nc
    73 maverick 4 door
    Im about to paint my maverick..its a 73 somewhat as a sky or baby blue color. I want to paint it back to original. Anyone know the name of the color and where i can buy it?
    Thanks,
    Mike
  2. blugene
    Not sure myself... I might try going into a auto paint store and look at some samples. The blue I want is competition blue. That is what I am wanting but I will compare it to some others side by side just to check out other possibilities. Just talking outloud, I see you want origional.
    Looks kinda like ->(y) Mine looks kinda like ->:idea:
  3. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
  4. rayzorsharp
    Do you have color code 3B on the door vin sticker?
  5. blugene
    So I see Grabber blue is the same as competition blue... I just don't see any competition in Grabber :D
  6. pitbull12888
    pitbull12888 Member
    waxhaw, nc
    73 maverick 4 door
    I looked it up on that maverick site and its light blue. Im trying to find the color online and havent had any luck so far....
    Heres the codes if anyone wants to help...i would appreciate it
    PPG-2403
    Valspar-L312
    Dupoint-5366
  7. blugene
    How much paint to paint our cars? Door jambs and under hood incl... Without an answer, i'm guessing 2gl...
  8. rayzorsharp
    That's probably a good guess. I really don't know the exact amount I used. I just mixed what I needed as I needed it. You also have to know if you are going to use single stage or base coat/clear coat. Base/clear you won't need as much color but lots of clear. Personally I would not use anything BUT base/clear.
  9. pitbull12888
    pitbull12888 Member
    waxhaw, nc
    73 maverick 4 door
  10. Mavman72
    How much paint you need(formula)
    It takes 7 oz per panel per coat on average.Colors with low coverage will require a bit more.Now decide how many coats you want to put down.
    Heres the formula:7oz per panel X number of panels X number of coats.
    This will tell you how much paint you need within a few ounces.:yup:
    Good luck.
  11. pitbull12888
    pitbull12888 Member
    waxhaw, nc
    73 maverick 4 door
    so you count the hood,front fenders,doors,roof,trunk lid, rear fenders?
    sooo 7x9=63 with 3 coats would be 189 ounces?
    correct?
  12. Mavman72
    :thumbs2:by jobe I think youve got it!!!!:dancing:
  13. pitbull12888
    pitbull12888 Member
    waxhaw, nc
    73 maverick 4 door
  14. Mavman72
    Except for custom colors(non production paints),most paint manufacturers use factory color codes for their factory colors.Which color are you looking at???
  15. pitbull12888
    pitbull12888 Member
    waxhaw, nc
    73 maverick 4 door
    light blue
