Name That Part!
Discussion in 'Technical' started by Trow, Dec 29, 2014.
  1. Trow
    Trow Member
    Fort Worth
    1974 Maverick
    It screws into the intake manifold and I believe that part of the A/c plugs into the end. There's also vacuum connections too. I just replaced my intake and the place where it should go is much larger than the threads on the original unit. What is it and where can I find a larger one or an adapter?
  2. rthomas771
    The name of the part is a DISTRIBUTOR VACUUM CONTROL WATER NECK VALVE ASSEMBLY. The adapter should had came with the intake...if not go to Napa and buy one
  3. Trow
    Trow Member
    Fort Worth
    1974 Maverick
    Sweet! Thanks so much!
