Need a good idea
Discussion in 'Technical' started by Jsarnold, May 7, 2012.
  1. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    The parking brake cable is touching my exhaust pipes and rattles at rpms around idle. This didn't happen before I had the pipes redone. Think the cable was tighter up against the previous exhaust pipes.
    So, I'm looking for a solution. The pipes probably get too hot for a rubber hose over the cable. Insulation around the pipes would wear thru in a short time. Hope I don't have to fab something elaborate.
    Is there a material that would be soft enough to dampen the vibration, tough enough to tolerate the cable rubbing on it, and heat resistant enough to tolerate the exhaust pipe.
    Surely others have had this issue. Solutions?
  2. Mav71
    Mav71 New Member
    1971 maverick
  3. simple man
    simple man Member
    Bunnell,Florida
    Real " simple ", get a spring that will hold the cable away from the pipe! It doesn't need to be much and you can still use the e - brake. Even though it may still touch the pipe when the e - brake is on ( won't hurt a thing ), you won't have rattles when you're driving! :)
  4. Mav71
    Mav71 New Member
    1971 maverick
    Or you could listen to Simple man as I have no mechanical skills what so ever.
    *Is a member of duck-tape fix's the universe Club*
    I know my fix would work..but a spring sounds like a real fix not a cheap quick fix :oops:
  5. Resto
    Resto Benders Evil Twin
    Yuma AZ
    I like the spring Idea. Or put a bottle jack with a 2x4 under the pipe and move it out of the way a little.
  6. Jsarnold
    '72 Sprint
    Sent a query in to ask if they thought that was a good application for Pyrosil tape. Never heard of a high temp rubber tape before.
    Wasn't thinking about a spring because the cable is UNDER the pipes so there's no place to attach a spring to pull the cable down away from the pipes. Gave me another thought though -- how about a spring to pull the cable snug against the pipes? Wasn't a problem with the previous pipes when when the cable was snug against the pipes.
    I just put a drive shaft loop in that happens to be right above the cable. Put a light carb return spring between the loop and the cable to snug it against the pipes. Started it up and no rattle yet. I'll have to see how it acts with different loads (in gear, alt driving elect fan, AC compressor running).
    Thanks for the ideas -- I was drawing a blank.
  7. Mav71
    Mav71 New Member
    1971 maverick
    I guarantee its a its a valid use of Pyrosil tape. We used it on high heat machine components at work all the time. But yeah, seems there are as many fix's as there are guys thinking about the problem. I haven't got my new exhaust system in yet... Thursday... so if this problem happens with mine, I am using the Pyrosil tape as I like fast, easy fix's on non critical or visual components. Besides I am biased, as it was my idea :rofl:
  8. simple man
    simple man Member
    Bunnell,Florida
    You could also get a spring that would go around the pipe. :)
  9. simple man
    simple man Member
    Bunnell,Florida
    You have a good idea, but the specs for the tape say 475°. The exhaust gets a lot hotter, I think? We'll have to have someone with a pyrometer to check it out! :)
  10. Mav71
    Mav71 New Member
    1971 maverick
    You could very well be right.. I have a hard time imagining a exhaust pipe getting hotter than the specs...but I never checked.. So might save some frustration of cleaning burned rubber tape by checking first :hmmm:
    I am sure we are all missing the easiest solution like a bracket clamp or sumin... lol
  11. Bryant
    put some header wrap around the pipe where the cable crosses. it will do the trick.
